Opinions on building a d16y7 motor??
Old Feb 25, 2017 | 01:44 AM
EFJDM1's Avatar
Default Opinions on building a d16y7 motor??
I have a bone stock 99 civic ek hatch with a d16y7 motor in it and I'm planning on building the motor and turboing it but I'm not sure where to start. Car is still automatic so I also want to swap the trans over to manual.
Old Feb 25, 2017 | 03:19 AM
joey1320's Avatar
Default Re: Opinions on building a d16y7 motor??
You should reconsider your options before spending any money/time on this project.
Old Feb 25, 2017 | 04:34 AM
skier's Avatar
It will be an expensive endeavor if you'll want it to actually last or be fast at all, but if it makes sense to you vs. getting a better engine swap since you'll already have to tear yours out- then power to ya (I budget-rebuilt my y7 and Manual swapped, and y8 swapped it last year after I replaced my EJ6 with a new daily, and am Turbo'ing it this year- causing a few arguments with the wife hehe)
First priorities if you want to actually drive it, should always be brakes; real coilovers; and just refreshing your suspension + steering components depending on your mileage (I assume high) then deal with the motor and trashing the auto
but as in other threads, what is the end-goal purpose of the build (drag/autocross/daily/fun weekend grocery-getter)? can't say too much without that as power-goal dictates what level of parts to get and how much cash you'll have to throw at it
Old Feb 25, 2017 | 10:46 AM
EFJDM1's Avatar
its going to be my daily for a while. I'd be happy with 200hp. Do you recommend just swapping a different and better motor in? Will it be cheaper if I do that?
Old Feb 25, 2017 | 12:08 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
It would be cheaper and more reliable to swap in a B18C1/B18C5 (GSR/Type R) into your vehicle.
180-200hp with bolt ons and a tune, or 300HP with a reliable turbo kit and tune.
Figure 4k to convert the car to manual and swap the motor, another 3k for the turbo kit and install/tuning..
You'd still be keeping your A/C with that estimate too.
Old Feb 25, 2017 | 12:11 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Also, D series engines will handle about 200hp before needing to upgrade rods, sleeving the motor, etc...transmissions top out about 350-400hp before you start snapping gears and needing to get a built one.
It is MUCH more cost effective to swap in a B series.
I'd even say spend a bit more, swap in a K series which is even more mod friendly...
Old Feb 26, 2017 | 02:27 PM
Customtoys_ek's Avatar
I was thinking about the same thing for my 97 ek sedan I might throw a vtec head and turbo it. This spring just for the hell of it and then just rock that until it's dead then do a swap.
Luisgil
13
Mar 24, 2015 06:49 PM
NubImports
May 10, 2009 08:43 AM
moosepoop21
Jun 13, 2005 01:27 PM
eymnewdc4
Nov 9, 2004 09:46 AM
