Y8 Vitara Build Pros and Cons??
Have had a couple people mention doin a Vitara build on the y8 im pullin out in a couple days wanted to see what i can find out
What are the pros and cons??
What specific years and motor am i looking for to pull parts from??
Most important with vitara slugs is to use custom length rods for them, if not your compression is going way to down. The price for a custom rod and piston kit is less expensive than a set of forged pistons alone.
YCP 75mm Vitara Pistons & Custom Length Rods Combo D16 |
Pros:
- Inexpensive
- Will suffice for most 3-400whp builds
Cons:
- Require custom length rods, otherwise static CR is garbage (like 7.8-8.2:1 IIRC)
- They're not the best option, but will do the trick.
OP: What is your power goal? I assume you're turbocharging it....correct?
- Inexpensive
Cons:
Pros:
- Inexpensive
Cons:
- Inexpensive
Cons:
huntarrr
28
May 9, 2022 08:14 AM
