2000 ls swap into a 1998 gsr shell
Old Feb 23, 2017 | 09:12 AM
drflyshigh's Avatar
Icon4 2000 ls swap into a 1998 gsr shell
so i'm installing a 2000 ls swap into a 98 gsr shell everything went in fine but the only thing that im having a problem with in that the ecu from the ls will mach two out of the three plugs.
i wanted to know what do i need to do to get it to work.
Old Feb 23, 2017 | 10:05 AM
tony_2018's Avatar
Fish Twig
Default Re: 2000 ls swap into a 1998 gsr shell
I think its best to tell us what you have in detail, is the 98 shell complete with an engine harness? obd2a ecu or obd2b? Does the 2000 ls swap have the engine harness?
Old Feb 23, 2017 | 05:03 PM
drflyshigh's Avatar
ok so I picked up a 98 gsr shell it needed a full swap so I picked up a 2000 ls and swapped over the ls motor transmission wire harness axles and exhaust, everything went in just fine but when I tried to install the ecu from the 2000 ls one of the plus wouldn't fit into that ecu That came from that ls. I've heard that the type r ecu will get the car to turn on, I just wanna know whats the best way to go.
Old Feb 23, 2017 | 06:31 PM
tony_2018's Avatar
Fish Twig
1. Do you have a jumper harness? 98 integra's use obd2a ecu's, not obd2b.
2. Do you realize that the obd2b ecu's have the immobilizer in them? You will not start the car w/o the matching key or the entire immobilizer setup.
Alt-right move is to find an obd2a p75 ecu.
nick91civicsi
Aug 1, 2010 02:24 AM
mc_civic213
Apr 10, 2008 05:18 AM
mc_civic213
Apr 10, 2008 02:05 AM
IloveAPC
Aug 31, 2004 09:45 PM
