LS OBD2B SWAP INTO EJ8???????
i have a 1999 civic ex and i am planning to swap in a 2000 ls motor soon. what kinda ecu should i get because i heard i cant use the 2000 ls ecu becasue of the immobilizer????
Re: LS OBD2B SWAP INTO EJ8??????? (mc_civic213)
If you plan on getting the motor BAR certified you can swap out the guts of the ecu that the LS comes with(i dont know what it is) with a b16a2 ecu and it should run the motor for the BAR test.
If not, i believe 99 LS did not have the immobilizer.
1999 ls ecu does not have a immobilizer but its obd2A and my civic is obd2B. would it run normal if i got a jumper harness and ran a obd2a ecu with my obd2b motor?
I have no idea.
Immobilizer can be removed but a CEL will always be on which wouldnt work if you plan on BARing it, if youre not, then do a search for the removal of the immobilizer.
mc_civic213
04-11-2008 06:22 AM
WCI
11-13-2004 09:08 PM
