LS/VTEC ECU PROBLEM!!!HELP
Old Aug 31, 2004 | 11:42 AM
IloveAPC's Avatar
Default LS/VTEC ECU PROBLEM!!!HELP
I have a 2000 LS with a 99 GSR head. My 2000 p72 GSR ECU Plugs into my LS Harness perfectly but it will not turn over for the life of it!!. I was told 2000's have immobilizers or something with the ignition that must match the ECU or have to be reset or something is that true? Any1 have a similar problem???? So for now im running my 2000 LS p75 ecu
Old Aug 31, 2004 | 12:38 PM
4U2NV's Avatar
Default Re: LS/VTEC ECU PROBLEM!!!HELP (IloveAPC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IloveAPC &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 LS with a 99 GSR head. My 2000 p72 GSR ECU Plugs into my LS Harness perfectly but it will not turn over for the life of it!!. I was told 2000's have immobilizers or something with the ignition that must match the ECU or have to be reset or something is that true? Any1 have a similar problem???? So for now im running my 2000 LS p75 ecu</TD></TR></TABLE>
You'll have to use the same key that came with the ecu you purchased, or send your ecu out to have the immobilzer removed... The key must match the ecu, that is why it won't start...
Old Aug 31, 2004 | 09:36 PM
IloveAPC's Avatar
Default Re: LS/VTEC ECU PROBLEM!!!HELP (4U2NV)
anyone know a place that will remove the immobilizer? or any1 know a better idea to make my motor run?
Old Aug 31, 2004 | 09:45 PM
shermanyang's Avatar
maybe try getting a 96-98 gsr ecu??
medijuandc2
Feb 26, 2013 07:09 PM
nick91civicsi
Aug 1, 2010 02:24 AM
mc_civic213
Apr 11, 2008 06:22 AM
crazyd
Mar 9, 2005 07:27 AM
