Confirming correct shift linkage
Old Feb 22, 2017 | 05:28 PM
Rez93del's Avatar
Default Confirming correct shift linkage
Hi guys, I've been doing alot of post reading on shift linkage, but need clarification please.
i found 94 del sol si d16z6 with vtec stamp on valve cover, I confirmed the Vin numbers to be sure of the engine.
My question is, can I use this shift linkage with my b18 engine/trans swap? Or do I need the b16 shift linkage from del sol, thank you in advance for any input.
Old Feb 22, 2017 | 06:20 PM
m90polk1's Avatar
Default Re: Confirming correct shift linkage
Single cam and double cam shift linkages are not the same, they mount differently to the transmission. You will need one from the b16 del Sol to work correctly.
Old Feb 22, 2017 | 06:37 PM
tony_2018's Avatar
Fish Twig
you need to locate the del sol vtec shift linkage.
Old Feb 22, 2017 | 07:23 PM
Rez93del's Avatar
Thank you for confirming and the clarification, very much appreciated!.
b16delsolnewb
Apr 1, 2008 05:31 PM
turbodelsol3
Mar 9, 2007 11:57 PM
solsi2000
Feb 13, 2005 03:09 PM
teawoboba
Jun 3, 2004 06:44 AM
b18bcivic
May 27, 2004 08:54 AM
