del sol dohc shift linkage what parts do i need??
I have a d16z6 right now and im going to swap a b18a in there. Can someone please tell me which numbers I need to buy to work with my swap. I would like to re-use some of my stock linkage if i could so just tell me each part that i need including every tiny bolt.
Re: del sol dohc shift linkage what parts do i need?? (solsi2000)
need adjustable shift linkage from Hasport or shortened shift linkage from 90-93 Integra . give me a while to get in further detail
Re: del sol dohc shift linkage what parts do i need?? (Honda V-Tec)
you'll need 14...and probably 13, as well as connecting parts (1, 30, 21, 15, 22, 18, 17, 31, 27, 24 and maybe 19, 10, 20, 28)
You need 14 and 13 no question,
The shift linkage in a sol is different then that of a civic, so basicly the best thing to look for is the shift linkage from a b16 sol.
Re: del sol dohc shift linkage what parts do i need?? (nocternaldragon)
yes i know the shift linkage is different from a del sol. that picture is of a del sol dohc shift linkage.
does anyone know about 19, 10, 20, 28?should i go ahead and buy those parts to? lmk thanks, mike
ok just making sure, but i dont think you need any of those parts you listed. It should be the same as your other linkage. The only two pieces i can see you needing are 14 and 13 Thats what sets your distance the parts you listed are just to attace it to the car so unless the parts you have are different i dont see a need for them.
Location: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon »</TD></TR><TR><TD CLASS="quote">ok just making sure, but i dont think you need any of those parts you listed. It should be the same as your other linkage. The only two pieces i can see you needing are 14 and 13 Thats what sets your distance the parts you listed are just to attace it to the car so unless the parts you have are different i dont see a need for them.</TD></TR></TABLE> I second this, all you need is 14 and 13 from the 1994 DelSol VTEC, 99-00 Si will work as well, they are the same part numbers. All the other parts are exactly the same as the SOHC so don't waste your money unless anything is missing. I would get 30 becuase the Honda manual says to replace that. Also invest in a 8mm punch, otherwise 30 is a bitch to get out. Spring pin is what they call it if I'm not mistake.
