Bad acceleration d15b7 engine!
Old Feb 21, 2017 | 05:48 AM
TetsukiMiz's Avatar
Default Bad acceleration d15b7 engine!
Okay so I have been having coolant loss and I figured out it's a headgasket issue so I'm replacing it but I'm also getting another issue with accelerating once I hit around 35mph right before it hits the 40MPH mark it makes a weird noise like its red lining I don't have an rpm gauge my car didn't come with it just a huge temperature gague my speed meter and the fuel gague but after it starts redlining it stays doing that revving sound until I take my foot off the gas then slowly push it down again then it passes 40MPH and it's fine after that it just does it around switching into 3rd gear I drive an automatic oh and when I first turn it on in the morning while it's cold everything works fine switches gears perfectly no hesitation or that revving noise and it drives so much faster it only happens after it heats up
Old Feb 21, 2017 | 06:06 AM
mk378's Avatar
Default Re: Bad acceleration d15b7 engine!
Don't drive with a bad head gasket. You'll burn up the engine.
Likely the transmission is going bad. Have you checked the fluid level?
Old Feb 21, 2017 | 06:19 AM
TetsukiMiz's Avatar
I have too I can't afford a mechanic to change the headgasket for me so i gotta learn to do it myself this Friday I'll get paid from work and then I can just go buy a new one
Old Feb 21, 2017 | 05:29 PM
tamboo's Avatar
10 Year Member
youtube can teach you a lot.
sent you a link to free factory service manuals.
good luck!
Old Feb 22, 2017 | 03:02 AM
Badcopyinc's Avatar
Had this issue on my sedan the throttle down cable to tranny was wearing out and needed adjusted. Once I did the car idled a little better and didn't need help to shift.
aemlet
Honda Civic (2001 - 2005)
Oct 5, 2013 01:56 PM
tecatown2091
Mar 6, 2013 05:35 AM
xsxnosxsx
Honda Civic (2006 - 2015)
Nov 23, 2011 07:05 AM
AVA
17
Apr 7, 2009 03:59 PM
OneFastLS
Jul 15, 2002 04:42 PM
