Failed attempt stealing my car left a broken ignition cylinder. Can't get it out
Old Feb 14, 2017 | 09:37 AM
scottishz's Avatar
Icon4 Failed attempt stealing my car left a broken ignition cylinder. Can't get it out
A thief tried to steal my Honda Civic 1997 and cut into the ignition cylinder pulling most of it out. I'm trying to replace it with a new cylinder, but I can't seem to get the one in there to move to the 1 position in order to depress the pin and pull it out. I'm not sure if there is something else I can do to try and move it. Is there a way I can get it to move? What are my other options at this point?
I can post a picture of it a bit later today. Any advice would be greatly appreciated!
Thanks!
There are some pictures below.
Last edited by TomCat39; Feb 14, 2017 at 03:24 PM. Reason: Adding in picture - Fixing img tag
Old Feb 14, 2017 | 12:26 PM
Badcopyinc's Avatar
Default Re: Failed attempt stealing my car left a broken ignition cylinder. Can't get it out
I'm by no means an expert with your issue but I've been doing a lot of research as of late to wire my car to unlock and start when it sees me approach it.but my main issue is the steering wheel lock that is bugging you right now.
with that being said a lot of threads on here covering removing steering wheel lock will tell you exactly all you need to know.
Old Feb 14, 2017 | 03:26 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Google search Honda Lock Cylinder Replacement and you will get lots of youtube video's that show how easy it is to remove the lock cylinder from the steering column.
Honda used break away bolts to secure the lock cylinder clamp to the column.
Old Feb 14, 2017 | 04:09 PM
jonsey1886's Avatar
10 Year Member
Remove the plastic steering column cover.
Left side under your turn signal/headlight controls you'll see a few phillips head screws. Remove those and your lock cylinder should now be free to remove.
Old Feb 14, 2017 | 10:23 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You will be replacing the whole lock system, which you will almost assuredly have to do as bad as they mangled that one. Watch this video and you will see he uses a punch to loosen the shear head bolts to be able to replace the whole lock mechanism.
Longer video demonstrating the same thing as well as install of the new one:
After this bit of learning, before you pull your's you should also google the 3 pins to punch your mangled cylinder apart for the tumblers and research copying your cylinder by pulling the tumblers and springs and put them into a junkyard cylinder:
https://honda-tech.com/forums/honda-.../#post38883876
Or you can order a new one with your VIN number direct from Honda and it will be keyed for your car.
Old Feb 14, 2017 | 10:28 PM
holmesnmanny's Avatar
richpin is a great mechanic, I love watching his vids. That's a genius way to remove those bolts. Normally a mechanic would drill them off.
Old Feb 14, 2017 | 10:43 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I always saw punch used, or corner of a flat tip you can beat on.
And I even saw a discussion where one person used a flat file and filed flats into the rounded bolt heads. I think they fought those with needle nose but the flats can be used as a good place to tap with your screw driver.
Another method I've seen is dremel flat tip type slots in the center top of the heads so you can use a normal flat tip to unscrew them.
Like Bryan M posted:
https://honda-tech.com/forums/honda-.../#post37957472
Tr0LL
Dec 23, 2011 04:04 PM
donut.
17
Jan 11, 2010 07:03 AM
Tomtheman70
Apr 28, 2009 06:43 PM
DerangedEG
Nov 17, 2004 02:59 PM
