What size throttle body?
Old Feb 13, 2017 | 05:47 PM
lxrd_vtec's Avatar
Default What size throttle body?
Hey HT,
I have a question regarding what size throttle body I should get for my set up as I'm torn between 66 or 68mm for my B18c1. I'm going to be keeping the block stock for now so I wanted to do the following:
Skunk 2 Tuner 1 Cams (w/ Supertech valvetrain)
Skunk 2 Adjustable Cam Gears
King Ported Edelbrock Performer X Manifold
AEM SRI with BPi 3" Filtered v-stack
PLM Tri-Y Long Tube Header
Vibrant Ultra quiet resonator (2.5")
2.5" Mandrel bent piping to 2.5" Vibrant Flat Black Muffler
Tuned on Hondata S300
I was originally planning on going with the 68mm TB and port matching the manifold. I wanted to do this so that when I go higher compression I can still utilize the same throttle body (to avoid buying parts twice really) and maximize the gains from it. I'm just a little concerned that 68mm may be a bit overkill for the stock GSR compression, what do you guys think?
Old Feb 14, 2017 | 04:18 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: What size throttle body?
68mm will be fine.
Old Feb 14, 2017 | 07:21 AM
lxrd_vtec's Avatar
Originally Posted by DumpdEJ6
68mm will be fine.
Great, thanks !
Old Feb 15, 2017 | 08:48 AM
Lau Cac Bo's Avatar
a 68mm tb is a good match for your build and goals.
Old Feb 15, 2017 | 12:51 PM
lxrd_vtec's Avatar
Thanks, just trying to avoid lego building s*** haha.
rico892002
Apr 21, 2011 02:32 PM
Kid_SiR
Jan 6, 2008 06:27 PM
dunkd
Mar 5, 2005 01:12 AM
stevieteg
Feb 25, 2005 10:56 AM
2k1_ITR_0736
Jan 25, 2004 05:06 AM
