2 jack stands on each side
I need to rotate my wheels on my 03 Honda Accord 4cyl, but I only have 2 jack stands. Is it ok to jack the car on its side with 2 jack stands only on the sides? If so then which jack point should I use for the hydraulic floor jack to lift so that I can place the stand under each of the reinforced beam on the front and rear. If I lift the car on the reinforced area then there isnt enough space to move the stand into position.
