Strange throttle/idle Issues
Old Feb 8, 2017 | 05:57 PM
Kman1371's Avatar
Default Strange throttle/idle Issues
On a trip home from a friends house the throttle and idle on my 92 civic si started acting funny. The car will hunt for idle bouncing between 1k and 2k rpms constantly. Also the throttle seems to have no response for about an inch or so of travel, and then it suddenly rockets to what feels like 50% throttle even though my foot has traveled less than an inch past what appears to be a sort of "Dead Zone" that was not previously there. Could my throttle position sensor need replacing? or is this something more serious?
Thanks for your input
Old Feb 8, 2017 | 06:47 PM
slomofo's Avatar
GDD Member
Default Re: Strange throttle/idle Issues
Do you have access to a volt meter?
Do you have any vacuum leaks?
Is there a CEL?
Is your coolant level full?
Old Feb 8, 2017 | 07:55 PM
Jimi Hondrix's Avatar
Remove and clean throttle body
Remove and clean IACV (replace rubber gasket if needed)
Adjust throttle cable tension properly
Old Feb 8, 2017 | 10:29 PM
Kman1371's Avatar
No CEL,
coolant level is good,
throttle cable tension appears to be good,
I'll check throttle body and clean it tomorrow morning, and I currently don't have a volt meter, I can pick one up from a parts store tomorrow and check for vacuum leaks
Old Feb 9, 2017 | 03:20 PM
Kman1371's Avatar
Found the problem! Somehow the bolts for the idle air control valve had gotten loose and the valve was loose and practically hanging off by the hoses. bolted it back up and everything is running smoothly again!
Thanks for the help
Old Feb 13, 2017 | 12:14 PM
Joseph Michaud's Avatar
Good find. Had something similar happen with my Del Sol. It would surge at idle. My IACV was connected fine, but was pretty dirty on the inside and there is a big plastic screw adjustment thingamajob in it. After thoroughly cleaning the valve, I screwed it in all the way, then backed off 1 turn, and that fixed mine. Much better than replacing $$$ or deleting it.
Old Feb 13, 2017 | 12:52 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
The "plastic screw thingamajob" as you've called it is the FITV (Fast Idle Thermo Valve). Not the IACV (Intake Air Control Valve).
Old Feb 13, 2017 | 12:59 PM
Thank you for the correction. Yes, now it all comes back. Both the IACV and FITV were suspect. In my case it was the FITV screw was wound all the way out (or possibly it was actually the cleaning that fixed it, and the screw position was a coincidence).
Old Feb 14, 2017 | 08:22 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
BIGef
May 4, 2012 12:16 AM
TonyRomo
Apr 30, 2009 07:06 PM
supracrx
Jan 7, 2007 08:06 PM
Mr. JDM-GSR
Aug 29, 2005 11:33 AM
GruvyTune
Aug 18, 2001 09:15 AM
