Wideband O2 sensor
Old Feb 7, 2017 | 10:25 PM
Sir001's Avatar
Default Wideband O2 sensor
I am new in the ECU tuning. Does the wideband O2 sensor can only fit tuned ECU like Hondata? Is it working in the stock ECU?
Old Feb 11, 2017 | 01:00 AM
80%downtime's Avatar
Default Re: Wideband O2 sensor
A wideband generally will not work with an ECU from factory. Most factory ECUs are programmed to read the voltages from a specific narrowband O2 sensor. If you use an aftermarket EMS, you're most likely going to have to input the correct voltages to reflect AFR. If you buy a wideband that can simulate a narrowband, then it'll be fine to plug it right in.
Old Feb 11, 2017 | 11:28 PM
Sir001's Avatar
Thanks bros.
Any brand of sensors have you mentioned simulate narrowband function?
Old Feb 12, 2017 | 07:21 AM
spAdam's Avatar
Loved
Community Favorite
PLX. It will still throw a heater code though. For a stock ecu the best thing to do is add a bung and run two sensors... your stock one and the wideband of your choice.
adamdecimals
Apr 1, 2010 01:05 PM
mike93eh
Nov 16, 2005 08:13 PM
mrduque
May 5, 2004 06:06 PM
FragSyndrome
Apr 7, 2004 12:34 PM
thinkbrianthink
Jul 19, 2001 03:59 PM
