Where does this plug go?
Old Feb 4, 2017 | 03:01 PM
90si-rex's Avatar
Default Where does this plug go?
2000 civic ex, bone stock motor/transmission. The motor was just rebuilt and I just got it back in the car and I have a mystery plug left over and can't figure out where it goes. It's located toward the passenger side back toward the firewall and under the air intake tube. Can someone tell me where this thing goes?
Also, the car cranks but won't start, but I'm reasonably sure that's a timing issue.
Old Feb 4, 2017 | 04:29 PM
90si-rex's Avatar
Figured out the plug but I still have a no start issue. It cranks but won't start. Thinking about more I'm not so sure it's the timing. I was extremely careful when putting on the timing belt to the point of being OCD about it. Anyone have any thoughts on what it might be?
Old Feb 4, 2017 | 06:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Where does this plug go?
Based on the location, my first suggestion would be the fan switch on the thermostat housing. However, there are a LOT of two wire round grey plugs on the harness... how about telling us what COLORS the two wires are so we can direct you properly.
Old Feb 4, 2017 | 06:36 PM
90si-rex's Avatar
Check my previous post. I figured that part out. Now I just have to figure out the no start issue.
Old Feb 4, 2017 | 09:16 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
What JR said. Tell us the wire colors and we'll tell you what it's for.
Old Feb 4, 2017 | 09:28 PM
Caoboy's Avatar
-Intl Steve Krew
Active Streak: 120 Days
Loved
Fuel, Air, Ignition, what don't you have?
Check your timing marks and make sure everything is lining up...
Old Feb 4, 2017 | 10:22 PM
eghatch9295's Avatar
Stancetard Hate Monger
double check grounds as well, specifically thermostat.
Old Feb 4, 2017 | 11:48 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You may think you have figured it out but there is a couple of two wire gray plugs that are interchangeable and if they are swapped will burn a component in the ECU.
Wire colors of the plug will tell a lot.
Old Feb 5, 2017 | 07:34 AM
90si-rex's Avatar
Yellow with a black stripe and the other wire is black.
Old Feb 5, 2017 | 11:24 AM
mk378's Avatar
Common reasons a newly installed engine might not start:
Thermostat ground not connected or loose
Sensors not plugged in, or plugged in wrong (check ALL wire colors, including the 3-pin plugs)
Distributor shaft engaged 180 degrees out of time
Spark plug wires in wrong order
No compression due to improper valve adjustment
Make sure the CEL comes on and goes out and the fuel pump primes when you turn key on and don't crank. Then hook up OBD scanner and confirm there are no codes, investigate any codes found.
Old Feb 5, 2017 | 12:23 PM
90si-rex's Avatar
All grounds are connected including thermostat. Compression is good. All plugs are connected and in the right spots. I'm checking the timing now. I'll check the distributor as well. I thought the ears (?) that came off of the distributor shaft that go into the end of the cam were different sizes though to keep it from being installed 180 degrees off? Also, CEL does not stay on, main relay clicks, and the fuel pump does prime. I also double checked just to be sure, and there are no codes.
Old Feb 5, 2017 | 02:54 PM
CX-Adam's Avatar
talks to himself
Community Builder
Are you sure it's not a BLK/BLU wire? Sounds like C138 which is your IAC plug (Intake Air Control Valve). It would look like this.
Like others have said, there are a lot of two wire gray plugs behind the intake manifold that all reach several sensors. It's common to mix them up.
Old Feb 5, 2017 | 03:17 PM
JRCivic1's Avatar
10 Year Member
Community Builder
There is no factory plug that contains the two wires that you have stated. I think CX-Adam is right about your wire colors... blue with a black trace and yellow with a black trace would be proper colors for the IACV and not the IAT as stated above. IAT is a similar plug with a red/yellow wire and a green/black wire. Check your electrical connections... just because a plug fits doesn't mean it is plugged in at the correct location. Now, also as stated above... you need fuel, air and spark. Check your spark plugs... are they wet ??? If not, you don't have fuel. While that spark plug is out, plug it into the plug wire you removed from and place it near something metal and turn the car over... do you have spark ???
Old Feb 5, 2017 | 03:26 PM
90si-rex's Avatar
Looking at it again it's blue/black.
As for the no start...yes, I have air, fuel, and spark. Looks like the timing was off. Just corrected that and I'm putting everything back together.
Old Feb 6, 2017 | 04:18 AM
CX-Adam's Avatar
talks to himself
Community Builder
Good catch. I miss quoted the Helm manual. I fixed my previous post. D'oh.
Did you get it running?
Old Feb 6, 2017 | 09:54 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You may want to check your ECU:
Transistor for Honda ECU spots labeled Q34 or Q31
Q31 is the transistor that commonly blows up when someone plugs the Purge Control Solenoid plug into the IAT sensor.
The IAT and the Purge Control Solenoid both use a two pin connector that fit each other from what I understand.
Old Feb 6, 2017 | 06:53 PM
crazyhorse2011's Avatar
10 Year Member
Loved
Old Feb 8, 2017 | 04:02 AM
HondaPartsHero's Avatar
Technical Hero
OBD2 IAT sensor is not round but square so they wouldn't swap.
Old Feb 8, 2017 | 05:57 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Good to know. Rules out that possibility. Nice to know Honda fixed that challenge for the 6th generation.
Old Feb 8, 2017 | 09:04 AM
Technical Hero
The OBD2 evap plug however is the same as the IAT so.....
Old Feb 8, 2017 | 06:45 PM
slomofo's Avatar
GDD Member
Jesus ******* Christ.
His issue is a no start.
If the plug was placed in the wrong location and the ECU fried a pin, NONE of the sensors affected by it would cause a no start issue.
I know he already solved his issue, but man, you people are the absolute WORST when it comes to helping people out in tech and somebody had to say it.
Old Feb 8, 2017 | 09:20 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Actually slomofo, a failed ECT sensor or unplugged/shorted ECT sensor makes it incredibly difficult to start a '90's model Honda engine... and it looks just like the plug that the OP posted in the picture.
Old Feb 8, 2017 | 09:28 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Sounds like someone is intimately familiar with OBD1 ECU schematics.
Can you share where these schematics are?
carlosd68
Mar 9, 2012 05:12 PM
IntegraGuy16
Aug 25, 2006 05:25 AM
gunner6696
24
Feb 19, 2006 11:34 AM
AIWFCIATR
Jul 23, 2004 11:54 PM
Shelby20psi
Apr 6, 2004 02:55 PM
