Suspension & Brakes Theory, alignment, spring rates....
04 accord.
Old Feb 2, 2017 | 06:18 PM
AJR1982's Avatar
Default 04 accord.
04 Honda Accord v6 Automatic
I just replaced both front wheel bearings and upper + lower arms. I'm putting everything together and and I'm having difficulty putting the CV axle spline into the wheel hub assy. Anyone run into this before?
Old Feb 2, 2017 | 06:39 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 04 accord.
A lot of people have trouble with this. Sometimes its just your technique that needs adjustment. Other times, its because you pulled on the axle and seperated the inner joint.
How are you doing this? Which ball joint is disconnected? And what position is your steering wheel in?
Did you pull on the axle or let it droop and seperate? Look at the boot closest to the trans. Does it look kinda stretched?
Old Feb 3, 2017 | 12:48 PM
AJR1982's Avatar
After hours of trying to put a round peg in a square hole I tried the axle but. Turns out Amazon sent the wrong parts.
boarding2008
Jul 29, 2010 05:56 PM
jca1972
Dec 22, 2005 03:52 PM
Getsch
Oct 24, 2005 03:02 PM
servion
Sep 5, 2003 11:33 AM
OEMaccord
Feb 21, 2003 06:22 PM
