OEM Door Hole Seal Glue?
Old Jan 27, 2017 | 08:11 AM
Tom B's Avatar
Default OEM Door Hole Seal Glue?
Just wondering what type of glue Honda use on those plastic sheet materials that are glued to the door behind the door card.
Anybody know what I mean?
Old Jan 27, 2017 | 08:25 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Default Re: OEM Door Hole Seal Glue?
It kinda looks like white/brown caulk??
Idk what it is, but i know what you mean.
Old Jan 27, 2017 | 10:13 AM
Tom B's Avatar
I found the OEM stuff. I'll post a part number for others to use.
Old Jan 27, 2017 | 12:10 PM
Tom B's Avatar
08712-0003
Old Jan 27, 2017 | 09:10 PM
Mt3c's Avatar
25 Year Member
I just did this about a month ago. I ordered 2, but one tube is enough. Also, make sure you figure out which plastic sheet is left/right side before applying
Old Jan 28, 2017 | 01:05 AM
Tom B's Avatar
Was one tube enough for both sides?
I've bought new OEM sheets for both sides. I'm wondering if the sheets will come with a small tube of this stuff. If not, I'll order some up.
Old Jan 30, 2017 | 05:39 AM
94eg!'s Avatar
#1 Super Guy
Loved
One neat thing I noticed with this stuff (at least the stuff that came on my 05 TL)....If you ever need to get into the door, just tug the plastic sheet outward and this adhesive will stretch. As it stretches, cut it down the middle with an x-acto. This leaves half the adhesive on the door and half on the film. Then when you're done, simply press it all back together for a weatherproof seal. It takes a little time, but it's well worth it.
Black Diamond
16
Aug 24, 2010 07:13 PM
Burlyirishdude
Mar 20, 2005 04:08 PM
B18Redline
Apr 15, 2004 11:27 AM
bemathew
Sep 16, 2001 09:01 AM
