96 accord camber options
Looking for interchangeable upper control arms to put some negative camber on my car. Per the rules have to run "stock suspension parts" so nothing adjustable. Heard you could run Civic uppers just don't know what years. Any help or other options would be sweet.
Thanks
Thanks
1996 HONDA ACCORD 2.2L L4 Caster / Camber Cam Bolt Kit | RockAuto
you will want the ones at the bottom and they will go into the upper control arm
For the fronts, your best bet is DA Integra arms. They may take some muscle to get in, but I believe they add about -1 degrees of camber up front. The EF Civic arms may fit as well, but will add even more camber. Not sure how much you really need.
For the rear, there is really nothing. The Accord suspension is pretty different to the Civic/Integra rear in that respect.
As bones stock as you can get besides poly bushings. Its for circle track, rules are tight since it's a stock class. Might try softer/cut springs if the arms don't help as much. About the only trick I know to get camber is different arms and something about moding the radius arm, but haven't figured that out yet
pasadena_commut
Honda Civic (2001 - 2005)
10
Apr 2, 2013 08:56 AM
FormulaIntegra
17
May 27, 2005 11:59 AM
RTW DC2R
Aug 10, 2003 03:40 PM
