Momentary rich afr when letting of the throttle
Old Jan 22, 2017 | 06:57 PM
b16a971's Avatar
Default Momentary rich afr when letting of the throttle
Stock b16a turbo
Hondata s300
550cc grams injectors
Walboro 255 fuel pump
Aem fuel pressure reglator
My afr goes to 12 afr then goes lean when letting off the throttle. Is it normal to go rich before going lean?
Old Jan 23, 2017 | 04:28 AM
gtpilot's Avatar
Default Re: Momentary rich afr when letting of the throttle
My NA motor does the same thing and the data log shows that it is just the ECU catching up to the inputs (MAP, Throttle Position, etc.) - I have never worried about it.
Old Jan 23, 2017 | 08:40 AM
motoxxxman's Avatar
what the guy above said is usually true.
a minor rich spike like that is nothing bad.
what would be bad though is if there's a lean spike when you quickly push the pedal down. if there's a lean spike, the tip-in enrichment needs to be adjusted.
booboo782
Engine Management and Tuning
Feb 3, 2014 06:28 PM
tianporn
Apr 24, 2012 07:17 AM
turboteg2nv
Nov 28, 2005 10:29 PM
GruvyTune
Nov 1, 2001 02:02 PM
raene
Jul 17, 2001 12:32 PM
