Main Relay ground location 99 civic hatch
Old Jan 20, 2017 | 08:51 AM
sundragon's Avatar
Default Main Relay ground location 99 civic hatch
Where is pin 2 of the main relay grounded, does it ground at the cluster of grounds located above the ECU on the right hand side kick panel?
I had a no power condition (no fuel pump, or other power supply items) on the main relay, temp ground at pin 2 solved the issue.
any help appreciated.
thanks
Old Jan 20, 2017 | 09:21 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Default Re: Main Relay ground location 99 civic hatch
G101
Old Jan 20, 2017 | 06:03 PM
sundragon's Avatar
That splains all the tomfoolery, work was performed on the cooling system, must have disrupted the ground to the main relay. Who'd have thunk it was terminated there! LOL
thanks much!
Old Jan 22, 2017 | 06:06 PM
CX-Adam's Avatar
talks to himself
Community Builder
No problem. Is everything working fine, now?
Old Jan 23, 2017 | 03:52 AM
sundragon's Avatar
Yes, all is well. Having that diagram was extremely helpful. Cleaned up all the grounds in the engine bay while I was at it, Runnin like a champ now, thanks again.
Old Jan 24, 2017 | 05:01 AM
cleanwerkz's Avatar
Ok guys sorry to but in, but i have a quick question on this subject....
If i jump 1/7 and the fuel pump works does that mean my g101 ground is bad?
( no spark and no fuel power )
also checked fuse 31 with the test light and it has 0 power also.
Old Jan 24, 2017 | 07:47 AM
sundragon's Avatar
Jumping pin 1 to 7 applies +12v from the battery to the fuel pump.
In normal operation the relay applies power to the fuel pump during cranking through pin 5 (ignition).
First thing you need to verify is if the relay (both sections) are energizing. One energizes when the ignition is switched on, the other when cranking.
If you don't hear the relay click on then off when you turn on the ignition, then you need verify if you have positive voltage at the relay with respect to ground. In my case I had no ground, thereby there was no path for current to flow from the ignition switch through the relay pull in coil back to ground. Thus, no fuel pump operation, no ECU power, or injector power.
If the relay is energizing and pulling in the contacts and you don't have current flow, odds are a most likely cracked solder joint (open circuit) or bad relay contacts. Very common for the cracked solder joints and or bad ground at the thermostat.
Here a couple links to get you on your way.
https://www.youtube.com/watch?v=QVxOQTSPyGY
https://www.youtube.com/watch?v=X5Qp-ToR8KA
Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
EatSleepJDM
Jun 4, 2012 09:45 PM
JAlvarez
23
Feb 9, 2011 10:18 AM
06turbocivic18
Apr 24, 2009 07:17 PM
DnB TeK
Jun 22, 2005 02:46 PM
DualCamEK
Nov 21, 2004 07:01 PM
