New guy needs a brain to pick.
Old Jan 19, 2017 | 02:14 PM
Dilln_MIH's Avatar
Default New guy needs a brain to pick.
I bought a hatch a while ago with a d16z6 swap. Things ratty as hell but I'm into it. It throws codes 1,3, and 17. The kicker is that it runs like a champ. Any input would be greatly appreciated. I want these codes gone before I turbo it.
Old Jan 19, 2017 | 02:23 PM
r_Senik's Avatar
Default Re: New guy needs a brain to pick.
1 is o2 sensor, 3 is the map sensor, and 17 is the speed sensor. Check all the wirings before you replace them.
Old Jan 19, 2017 | 03:08 PM
Dilln_MIH's Avatar
Thanks man. I'll do that but how does it run so strong still? Are those things not detrimental to performance?
Old Jan 19, 2017 | 04:14 PM
mk378's Avatar
O2 sensor will reduce your mpg and increase smog but performance still OK. 17 doesn't change much at all (does the speedometer work)? The MAP is kind of important.
Whenever you have more than one code, clear them and drive just until the CEL comes back on, then read again to see which one(s) reoccur first. You can be looking at old codes that were for transient problems.
Miggylowks
Feb 21, 2014 01:22 PM
Belarus
Mar 30, 2010 12:58 AM
Groove_D
Jul 11, 2007 12:30 PM
Cuong-nutz
26
Nov 7, 2005 10:04 PM
pinoyboy204
Nov 2, 2003 07:06 PM
