2 step on 5 speed swapped da9
Old Jan 17, 2017 | 03:54 PM
Teggy714's Avatar
Default 2 step on 5 speed swapped da9
How do I wire the clutch so I can activate the 2 step on my ecu..this is for a 93 da integra...by the way I'm a noob..
Old Jan 17, 2017 | 08:06 PM
fastfob's Avatar
Default Re: 2 step on 5 speed swapped da9
Are you looking for the switch that knows when clutch is in/out or are you legit asking how to completely wire up a 2-step?
Old Jan 18, 2017 | 03:08 AM
Teggy714's Avatar
well I wana know how to wire the clutch so my ecu will know when the clutch is in and out...
Old Jan 18, 2017 | 01:50 PM
thewrai6th's Avatar
What ECU and what tuning software?
Old Jan 18, 2017 | 02:39 PM
Teggy714's Avatar
I don't have one in yet i just swapped my auto tranny for a 5 speed and got rid of the auto ecu wich was the pr4...
Old Jan 18, 2017 | 10:03 PM
Da9willie's Avatar
Get the sensor from another car somewhere of you can and rig it up to ur new clutch maybe? And get a p75 I think it is. Stock ls ecu but make sure it's from a 5 speed
Old Jan 19, 2017 | 04:46 AM
Teggy714's Avatar
do you mean the clutch safety switch
Old Jan 19, 2017 | 11:11 AM
MotorMouth93's Avatar
10 Year Member
You need to be a lot more specific with your questions, installing 2 step launch control is typically extremely straightforward but what that entails exactly depends entirely on what 2 step system you use.
Either way, you need to get the car running properly first. And then you need to do a ton of research on what sort of 2 step system you want so you can actually ask coherent questions that make sense.
Old Jan 19, 2017 | 12:39 PM
Teggy714's Avatar
I'm pretty sure I had said it was on the ecu?i was simply asking how to wire the clutch so the ecu would know when my clutch is in or out.And I already mentioned that this was on a auto to 5 speed swap on a 93 da.i appreciate it buddy but not helping...
Old Jan 19, 2017 | 05:55 PM
10 Year Member
You haven't told us what ECU you have or how it was chipped, without that info there is no way anyone can give you any useful information.
Old Jan 19, 2017 | 06:14 PM
Teggy714's Avatar
oh really i apologize I figured that all chipped ecus would activate the 2 step the same way.wich would be When the clutch is pressed in.i guess I'll wait and ask again when I have the ecu in thanks.
Old Jan 19, 2017 | 06:57 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
You should find out what you are working with before you jump in blindly and ruin your car.
Old Jan 19, 2017 | 08:05 PM
Teggy714's Avatar
I'm out of here you guys are not helpful at all
Old Jan 19, 2017 | 08:10 PM
Caoboy's Avatar
-Intl Steve Krew
Loved
Yeah you're right, we're only trying to help you not destroy your car, but those fb groups that tell you what you want to hear are more helpful in encouraging you to blindly engage in something you obviously know nothing about.
Enjoy your blown up car.
Old Jan 20, 2017 | 03:44 AM
Teggy714's Avatar
how will I blow it ? If anything give me advice don't bash me
Old Jan 20, 2017 | 01:28 PM
thewrai6th's Avatar
Without knowing the pinout of your ECU, you could certainly destroy your ECU (and engine if you really F'd something up). Most people are here just to help fellow car enthusiasts.
If you want I can guess at your ECU (OBD1 P72) so your answer is B-7
Old Jan 20, 2017 | 06:06 PM
solomon93's Avatar
Why did you get rid of the pr4? Assuming it was obd1, you could have converted it to 5 spd for $0 in less than 10 minutes. You dont need to wire in the clutch switch for crome btw, its based of the speed sensor to determine if the car is moving or not.
Ronaccord
Transmission & Drivetrain
May 5, 2017 06:43 AM
JaimmyACA
May 26, 2013 06:24 PM
julezeve
Honda Civic (2001 - 2005)
11
Jul 26, 2009 02:03 PM
SpeedingHatch
May 22, 2006 09:58 PM
