How to Fix Slop in B Series Shift Linkage?
Old Jan 14, 2017 | 08:27 PM
CHANCELLOR12's Avatar
Icon5 How to Fix Slop in B Series Shift Linkage?
Hey, I've got a 97 Hatch with a B16a swap. The shifter has excessive play left and right while in gear and you can even notice it in neutral as well. I got under the car and where the spring pin goes through the linkage and connects to the tranny, the shift linkage was worn in an oval, causing the linkage to be loose at the spring pin.
I'm wondering if there is an easier/cheaper fix than replacing the whole shift linkage?
Thanks
Old Jan 15, 2017 | 03:17 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: How to Fix Slop in B Series Shift Linkage?
Use the hasport shift linkage rebuild kit.
Old Jan 15, 2017 | 05:19 PM
I've never heard of it, and can't find anything online? The closest I can find is the Innovative Shift Linkage End Joint, and that would fix my problem but I dont know how I would mount it to the stock b16 linkage.
Old Jan 16, 2017 | 09:43 AM
Hasport's Avatar
you can call or email us for a linkage repair kit
Old Jan 16, 2017 | 08:09 PM
94eg!'s Avatar
#1 Super Guy
Loved
You didn't look very hard. I googled "Hasport shift linkage repair" and got this in the #2 spot...
Is your Hasport shift linkage as loose as a 2 dollar *****? Hymen Restoration. | HondaSwap
Old Jan 22, 2017 | 09:12 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Is your Hasport shift linkage as loose as a 2 dollar *****? Hymen Restoration. HondaSwap
That is a nice write up!
Old Jan 22, 2017 | 11:57 AM
turbociv910's Avatar
buy all new shifter bushings from honda on the shifter end, buy a ES kit for the bushings, and get rid of the oem coupler and have a steering joint welded in place. Requires some fab but gets rid of oem coupler that is crap to begin with.
Old Jan 22, 2017 | 04:05 PM
Premium Member
Loved
Community Favorite
Still uses bitch pin?
Old Jan 23, 2017 | 07:48 AM
Hasport's Avatar
the oem u joint isnt crap per say its just that most every 88-91 leaks oil and that destroys the u joints
Old Jan 23, 2017 | 06:46 PM
slomofo's Avatar
GDD Member
This is one of the most idiotic things I've ever seen.
vtecc
Jun 1, 2015 10:53 PM
user7889
Sep 28, 2008 03:27 PM
teamV eg
Feb 7, 2007 07:59 AM
SupraRXZ
Feb 9, 2006 04:35 PM
