No power to main relay and fuel pump
Having trouble getting power to Main relay and fuel pump is not priming, I replaced fuses new ecu new main relay and new fuel pump I know all parts work because I tested them on my other civic before I put them all in, so I know parts work, I don't where else to look I have check all grounds except fuel pump ground which I will do, but when I turn the power on noise at all from main relay and no priming noise from pump so idk what else to do, any Advice helps
hondaluver12
Jan 30, 2012 02:37 PM
insomniac791
Jan 22, 2004 04:23 PM
