Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Starting problems
Old Jan 5, 2017 | 05:06 PM
poprocksncoke's Avatar
Default Starting problems
03 Accord LX, wouldnt start or crank. Took starter out and had it tested, it failed the test. Bought new starter and replaced it. Car started fine at first but now wont start consistantly. It cranks but wont start, will start right away if jumped and starts ok for a couple days before needing to be jumped again. Battery reads 12.4 on multimeter and alternator read 14.3. What should I check next?
Old Jan 8, 2017 | 02:46 AM
poorman212's Avatar
Default Re: Starting problems
Best to go ahead and pull the battery and have it tested, without a load it might read ~12v but testing with a load will show it there are signs of an issue with it. While it is out, clean the terminals and when you re-install be sure they are tight.
Old Jan 23, 2017 | 11:36 AM
Worked for a while, now wont start again, wont crank either. The starter clicks but wont turn over. Had the battery checked, its good. Checked for power to the starter, alternator and fuse box, all good. Took out the alternator and had it tested and it was good too. Not sure what to do?
Old Jan 23, 2017 | 12:07 PM
Forgot to add, I changed the battery post connectors as well. Before when the car wouldn't start, after the starter replacement, I was able to jump it now it wont even jump start.
Old Jan 25, 2017 | 11:56 AM
No one?
Old Jan 28, 2017 | 04:56 AM
poorman212's Avatar
Test the voltage at the starter. Pull the small wire from the starter solenoid - yes, not fun if you have a 4 cyl as it is under the intake - and as someone tries to start the car measure the voltage on the wire.....what is it showing? I know you replaced it recently but please follow along.
IF you are getting batter voltage on the wire to the solenoid (BLK/WHT I thing - too lazy to verify), check the "larger" cable to be sure it is tight, might have worked lose after the replacement. If it is tight then go ahead and pull the starter and have it tested.
If you ARE NOT getting battery voltage on that small wire, we need to work "back up" the circuit to find out why.
JDMdb8isO
Feb 6, 2011 12:58 PM
EGHondalover88
31
Jan 18, 2010 03:26 PM
xander1100
Oct 18, 2009 07:56 PM
jorge59la
Sep 27, 2007 07:24 PM
rafiq7
Dec 14, 2004 07:46 AM
