94 EX Ignition Swith on its way out?
Old Jan 5, 2017 | 04:02 AM
LiteraCola's Avatar
Corvette Forum Member
Default 94 EX Ignition Swith on its way out?
Good morning, guys. The last few days of driving my car before the trans rebuild, I noticed that when I would start the car, the stereo (aftermarket head unit) would beep, as it does when you turn off the car. The stereo would beep and the head unit would be dark, along with the light on my iPhone charger.
For ***** and giggles, while the car was running, I turned the key JUST BARELY to towards Crank, but not far enough to engage the starter. Suddenly, the stereo would light back up and everything would work fine. Could it be that my ignition switch is getting ready to go? Thanks
Old Jan 5, 2017 | 05:29 AM
94CivicSi's Avatar
Default Re: 94 EX Ignition Swith on its way out?
Sounds like it. The switch is an all plastic assembly that bolts to the ignition lock and the interface between the 2 can get sloppy over the years. If you remove the column cover, it's facing the drivers' door. Pretty simple to access if you wanted to give it a closer look.
Old Jan 5, 2017 | 06:57 AM
White_EG1's Avatar
Just play with the key a little bit. Go from on(l) to on(ll) a few times radio acting funny? Cluster lights too? Then it sure is.
Old Jan 5, 2017 | 08:43 AM
LiteraCola's Avatar
I kind of figured it might have something to do with the ignition switch, considering it can be changed/fixed just by moving the key around. Good deal. Thanks guys
JohnKam
Oct 8, 2017 04:50 AM
Hughes07
Mar 26, 2013 05:24 AM
EnviedByMany
Dec 16, 2010 05:34 AM
aquito
12
Jun 17, 2009 05:26 PM
skamal
Dec 9, 2007 08:37 PM
