No fuel car won't start
Old Jan 4, 2017 | 04:26 AM
Jose A Aispuro's Avatar
Default No fuel car won't start
93 Eg hatch d15b7 Auto, car does not get fuel, it doesn't even sound like fuel pump is priming, I have replaced (Fuel Pump Fuel Filter Main Relay Dizzy Plugs Wires all fuses and the Ecu) and still nothing I know they all work cause I have tried all the parts on my running and driving coupe, not sure where to start next any advise will help thanks
Old Jan 4, 2017 | 06:05 AM
94CivicSi's Avatar
Default Re: No fuel car won't start
You checked all under dash and under hood fuses?
Double check your under hood ground connections.
Old Jan 4, 2017 | 08:14 AM
Former User's Avatar
Post the CEL codes, and also test for spark.
Old Jan 6, 2017 | 02:19 PM
lolv8s's Avatar
10 Year Member
make sure the fuel pump is getting a good connection. did it click when you plugged it in?
Old Jan 6, 2017 | 05:17 PM
[QOTE=94CivicSi;51156479]You checked all under dash and under hood fuses?
Double check your under hood ground connections.[/QUOTE]
Yes I have checked all fuses and double checked them all again, I have anther Dizzy I am gonna try out, maybe the one I have doesn't give it enough spark
Yes I have checked all fuses and double checked them all again, I have anther Dizzy I am gonna try out, maybe the one I have doesn't give it enough spark[/QUOTE]
also all the grounds are good no spliced or burnt looking wires
Old Jan 6, 2017 | 05:18 PM
I will test to see what codes are running
b16hatch620
Sep 19, 2010 06:42 PM
josejdm
Jul 28, 2009 12:31 PM
jOnW89
10
Jul 15, 2009 02:07 PM
jbscivichb92
Apr 25, 2005 08:31 PM
Tinker219
May 26, 2004 04:12 PM
