Still Getting Code 0 :'(
Old Jan 2, 2017 | 12:50 PM
pitti's Avatar
Default Still Getting Code 0 :'(
hey peeps. havin a mental breakdown here lol. i have a b18c1 in my 92 teg. was running good until 1 of my injectors went down so figured since i had it apart id get a whole new set. bing, bang, got it done but when i tried to turn it over she threw a code 0 at me ordered a new ecu and still getting code 0. removed, sanded and reconnected all ground wires but once again
PLEASE!! any and all suggestions are greatly needed and appreciated. motor is all N/A except skunk2 pro series i/m
Old Jan 3, 2017 | 09:26 AM
civic402lx's Avatar
Default Re: Still Getting Code 0 :'(
Does the car start and run?
Old Jan 3, 2017 | 09:28 AM
feels's Avatar
Hi pitti,
If you have cleaned all the ground wires, as well as new ECU, then I wonder whether the battery voltage is low. Try charge the battery, or connect another battery in parallel. Recently I tried to connect a power drill battery in parallel to jump start my car, which is DeWalt 20V li-ion battery. You can use 18V, 12V cordless power tools battery, if you have those laying around.
Hope this resolve your problem
Old Jan 3, 2017 | 08:11 PM
solomon93's Avatar
Hmm code zero after you played with injectors? You are referring to a SOLID CEL, yes? Disconnect the negative on the battery. Disconnect your injector plugs from all 4 injectors. Re-attach negative cable to battery. Turn the key to ON but do not try and start the car. Does the CEL shut off as it should?
Old Jan 6, 2017 | 07:01 AM
pitti's Avatar
no. Cranks but wont catch
Old Jan 7, 2017 | 10:51 AM
pitti's Avatar
hi solomon. Sorry for delayed response, car is at dads farm. Solid light yes. Did as you said but light is unchanged
Old Jan 7, 2017 | 11:19 AM
pitti's Avatar
Originally Posted by feels
Hi pitti,
Hello. There is full charge on battery thanx
Old Jan 8, 2017 | 04:45 AM
HondaPartsHero's Avatar
Technical Hero
So just so I'm on same page you go to turn the key and the check engine light should turn on for 2-3 sec and turn off but instead it stays solid? Sounds like potentially a bad main relay or possibly a bad ECU.
Old Jan 8, 2017 | 08:39 AM
pitti's Avatar
yes. cel stays on. just bought another ecu from ebay. seller had a great reputation ranking with lots of positive feedback/comments.
umm... main relay is fuse under hood right? if yes then all fuses look ok, no burnt filaments.
Old Jan 8, 2017 | 03:25 PM
Technical Hero
No
Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
Old Jan 9, 2017 | 02:16 PM
pitti's Avatar
Woohoooo!!! Im back on the road again. That link that you sent was fantastic! Exactly what i needed and quite detailed. Huge thank you kind sir.
Old Jan 9, 2017 | 04:47 PM
Technical Hero
Awesome!
Tom's hybrid
Honda Civic (2001 - 2005)
Jan 7, 2013 04:02 PM
daver321
Dec 25, 2008 06:39 AM
nihad
Aug 14, 2007 07:03 PM
zak88lx
Oct 5, 2005 10:55 AM
