critical to replace trailing arm bushings?
Old Dec 28, 2016 | 11:35 AM
Slade Exulis's Avatar
Default critical to replace trailing arm bushings?
I'm wanting to start refreshing the suspension on my bone stock 91 Civic STD. Right now I don't have the time or the tool to change the trailing arm bushings. Can I safely wait another month or two to replace them? This car is my daily driver and will continue to be during the time I'm waiting to take care of the trailing arm bushings.
Here's a list of what I can get done right now:
new KYB shocks
new TEIN springs (should only drop 1-1.5in)
upper and lower ball-joints
front lower control arm bushings
rear lower control arm bushings
rear upper control arms
To restate my question, is it safe/will it not cause damage if I replace all these parts but wait a month or two on the trailing arm bushings?
Old Dec 28, 2016 | 11:38 AM
testify's Avatar
On vacation
Default Re: critical to replace trailing arm bushings?
A months time won't have an effect on your RTAs.
When it comes to car parts, driving the car has a much greater effect on longevity than the passing time does.
Old Dec 28, 2016 | 11:57 AM
I guess I should have mentioned that I will be daily driving the car during the 1-2months.
Old Dec 28, 2016 | 12:03 PM
testify's Avatar
On vacation
It will be fine.
Old Dec 28, 2016 | 02:36 PM
DWP_Racing's Avatar
YOU DONT NEED A TOOL FOR THE BUSHINGS. WHITE LITHIUM GREASE AROUND THE OUTSIDE OF BUSHING AND PRESS IT IN. IT WAS FAIRLY EASY FOR IT TO GO RIGHT IN.
Old Dec 28, 2016 | 02:47 PM
testify's Avatar
On vacation
Trailing arm bushings have a metal sleeve around them and must be pressed in. I've seen some people manage to pound the OE ones in with a hammer.
But going at it with grease and muscle, not a chance.
Old Dec 28, 2016 | 10:38 PM
solomon93's Avatar
I would grab an inexpensive set of DA rear trailing arms and press new bushings in those and then bolt them straight up. no downtime and upgrade to a more efficient/effective disc brake setup. Win-Win
Old Dec 29, 2016 | 07:00 PM
AllMtorEg's Avatar
if you unbolt some if the arm and let it hang down you can beat the old one out and the new one in with hammer. pay attention how far it goes in tho.
Old Jan 1, 2017 | 01:27 AM
24TEN's Avatar
PHANTOM MENACE
Got mine done with a 5lb sledge and some very heavy hits.
Old Jan 1, 2017 | 03:49 PM
JamesS's Avatar
What's the procedure to clock these bushings?
Old Jan 1, 2017 | 04:04 PM
24TEN's Avatar
PHANTOM MENACE
Simple thing is to match them to the original orientation. On mine I had eyeballed where they would sit naturally with my lowered suspension.
Old Jan 3, 2017 | 01:47 PM
DWP_Racing's Avatar
SORRY I DIDNT SPECIFY. I REPLACED MINE WITH THE ENERGY SUSPENSION BUSHINGS. BURN OUT OLD BUSHINGS... LEAVE IN SLEEVE... PRESS IN NEW BY HAND... EASY UPGRADE!
PatrickGSR94
Suspension & Brakes
44
Jun 13, 2013 03:28 PM
airikkCRX
Jan 24, 2011 04:01 PM
kasperxtcy
Suspension & Brakes
Mar 24, 2010 09:14 AM
Chase Taylor
Apr 7, 2004 04:06 PM
Nader_D
Sep 2, 2003 01:14 PM
