Please help! Cylinder 2 and 4 misfire
Old Dec 28, 2016 | 03:59 AM
Slammed97coupe's Avatar
Default Please help! Cylinder 2 and 4 misfire
I have a 96 according 2.2l vtec and I am having and issue... it's throwing cylinder 2 and 4 misfire and has a stumble between 2-2500rpm car has brand new cap wires rotor plugs dizzy and egr and number 2 injector all installed from p.o in last 2 months before I got the car when I bought it the stumble was only at 2k now it ranges from 2-2500. Now it only stumbles under load light occasionally flashes while driving. The according only has 126k on it and is automatic
Old Dec 28, 2016 | 07:47 AM
Default Re: Please help! Cylinder 2 and 4 misfire
Anyone?
Old Dec 28, 2016 | 04:26 PM
holmesnmanny's Avatar
clean the egr ports
Old Dec 28, 2016 | 08:22 PM
MAD_MIKE's Avatar
MM Gruppe B
Real easy to clean the EGR manifold mounted on top of the intake. Use a #1 & #2 flat head screwdrivers to hand drill out the ports, they are stepped. Use a vacuum to suck out the carbon/soot while hand drilling. #1 flathead fits the passages in the EGR manifold. Just do not scratch the coated surface of the bottom plate(#17).
Old Dec 29, 2016 | 04:34 AM
I'm new to Hondas the photograph helps a bit but what all will I need to remove to do this? And will I need to buy any replacement gaskets?
Old Dec 29, 2016 | 10:34 AM
do a youtube search for "eric the car guy honda egr port cleaning"
Old Dec 29, 2016 | 05:36 PM
Would the evap solenoid have anything to do with the stumble the car is having and the fact that the intake is crap?
Old Dec 30, 2016 | 10:55 AM
evap problems will not have a noticable effect on performance, but egr will
Old Dec 30, 2016 | 12:00 PM
rode2nowhere's Avatar
good picture
Old Dec 31, 2016 | 07:37 PM
MAD_MIKE's Avatar
MM Gruppe B
Fuel rail(#5) and injectors(#1) will need to be removed to gain access to the EGR manifold. Not hard to do, there are two or three nuts(#33) and two more bolts(#35) that hold the hardline(#6) from the FPR/return fuel line bolts. Small bungies to hold the fuel rail away while cleaning the EGR manifold makes it much simpler(unbolting the return line from the fuel rail allows more free movement, do not unbolt the FPR(#9) itself) No need to open the fuel feed or return lines. I've had luck in removing the injectors and fuel rail all in one piece. Once those are out of the way you should be good to go.
There was a writeup in the FAQ at the top of the page on how-to.
If EVAP was failing you would either have a constant issue, not a 2K-2.5Krpm issue, or a gradual loss of power til the car becomes almost undriveable.
For stock engine/ECU/trans gearing, the intake is fine. It does become a choke point in the higher revs, but you will have to change other things before the intake itself is the power limiter.
Old Jan 6, 2017 | 05:20 PM
Cleaned out the ports works like a dream now! Thanks know you for the help!
eg9_fann
Mar 3, 2011 02:49 PM
Rizo96DC2
Aug 2, 2010 03:58 PM
tred
Mar 28, 2008 04:55 AM
BoostedJeff
Aug 9, 2006 07:17 AM
BoostedJeff
Jun 16, 2006 03:14 PM
