T-stat ground can cause injector failure
Hi, I was having problems with injector ground specific in injector 3, after check for continuity and T-stat ground cleaning, now its working fine. I'm a little worry if the ground was the culprit or tweaking the harness fix it. The T-stat can cause this failure? Because if not the harness is failing.
Thanks
Thanks
It would be odd that an improper ground at the thermostat would only result in issues with the #3 fuel injector. It is much more likely that there is a problem with the ground wire for the #3 fuel injector or a potential intermittent failure of the injector driver itself inside the ECU.
Thanks a lot, Now I'm going to drive a wire from the ECU plug to the injector ground for testing and twist and move the harness. If this don't work, is there a way to test the ECU driver?
A noid light or 12V LED type test light can be used to test the ECUs injector output leads.
The Thermostat ground(s) are for the ECU and the PGM-FI Main Relay, [injector relays coil ground] it would effect power to all the injectors and power to IGP 1 and 2 to the ECU and some engine sensors and valve. /solenoids.
I agree this sounds like a problem with the ECU or wiring/connections between ECU and the bad injector. 94
The injectors are ground side switched. They all have a common hot wire (yel/blk) running to them and the negative (switched) side of each injector 1 - 4 goes straight to the ecu at pins A1, A3, A5 and A2, respectively. The 12V hot comes up from one of the power distribution blocks under the intake manifold.
