Fuel Injector Stuck Open??
Old Sep 24, 2002 | 01:50 PM
SC94DB8's Avatar
Default Fuel Injector Stuck Open??
When this happens, is it usually a faulty injector......or is it more likely to be a wiring problem?? I am really just trying to figure out what actually causes it to become stuck.
Reason I ask is because I had my motor apart for a few weeks getting some work done to the head. Now, after putting it back together, I have the #3 injector stuck open. I just can't figure out why it is open now and I had no problems before the motor was apart. TIA everyone.
Old Sep 24, 2002 | 01:58 PM
Perfectionist's Avatar
Default Re: Fuel Injector Stuck Open?? (SC94DB8)
Normally, the ECU completes the circuit to ground for each injector at the correct time. Maybe you shorted the wire for the the #3 injector to ground (between the injector and ECU)? Or, your ECU could be bad, but you said you didn't have any problems before the head work.
Old Sep 24, 2002 | 02:09 PM
Chiovnidca's Avatar
It's usually a bad injector. I usually call them leaky injectors. If you think you have a wiring problem, swap two injectors and see if the same cylinder is acting up or not.
Old Sep 24, 2002 | 02:23 PM
SC94DB8's Avatar
Default Re: Fuel Injector Stuck Open?? (Chiovnidca)
In the case that I have a "leaky injector", could a good cleaning fix the problem, or would this indicate that the injector is completely done for.
I am trying to diagnose whether the injector maybe got gummed up from sitting out of the car for a while.
[Modified by SC94DB8, 6:24 PM 9/24/2002]
Old Sep 24, 2002 | 05:54 PM
Chiovnidca's Avatar
It wouldn't hurt to try. You might get lucky.
chintanwall
Honda Civic (2001 - 2005)
Sep 17, 2016 01:06 AM
B_Swapped93
Apr 24, 2013 08:44 PM
codyw
Apr 29, 2010 02:23 PM
mickey b16
May 18, 2009 07:33 PM
lastturn
Oct 25, 2005 11:55 AM
