DEC FS
Old Dec 6, 2016 | 07:31 PM
crazes's Avatar
Moderator
Default DEC FS
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Dec 7, 2016 | 06:32 AM
hondaracing84's Avatar
Default Re: DEC FS
Starting a new project so I need to get rid of some parts I no longer need.
All parts are used but in good condition. Paypal required unless local pickup, buyer pays PayPal fees. And sorry, no international.
Serious inquires only. PM me or for quicker response text 580-382-1661.
I am willing to do trades if its a part that I need for my new project. So let me know.
Supertech 100 series flat face performance valves. These ARE the performance valves and have the logo at the top of the stem. Half are brand new in package the other half are used. - $150 shipped
Eagle LS length rods. Used for 2 seasons in an all motor application. Rod bolts torqued a few times when checking bearing clearance and twice for final assembly each season. - $200
ALL MOTOR AEBS sleeved GSR block w/caps. All motor 86mm bore, needs hone. Pistons to match can be included for extra cost, listed below. Block once was turbo, so it had o-ring grooves. Copper rings were pressed in and smoothed out to fill grooves. - $600 + shipping. Local pickup preferred, will drive to surrounding areas or meet halfway to deliver.
86mm Supertech 13.5:1 compression pistons. Used. One cylinder had some detonation and resulted in some marks on the piston. I will sell the pistons by themselves or with the block. Needs new rings. Comes with wrist pins. - $165 or $150 w/block
4.92 gearX straight cut B series final drive for B16/LS sized diffs. Perfect for all motor B series. Used for 2 seasons. Gear is still in transmission, so I don't have any pics at the moment. But I will send pics before I ship. - Sold
Old Dec 11, 2016 | 06:26 PM
SPOOLINmatt's Avatar
Default Re: DEC FS
*Hondata injector driver: $300 OBO
Used for 1 dyno session, 4 track outings.
Price includes shipping to the 48
706-346-6024
It has worked flawlessly and very easy to setup. I set it up in 5 minutes after wiring it up. Anyone can add this to their existing tune with very little adjustment! It actually will work without even touching it but minor adjustments make it work the best
Old Dec 12, 2016 | 04:59 PM
rmercado's Avatar
Default Re: DEC FS
FS BMC CUSTOM BILLET INTAKE MANIFOLD. CUSTOM FLANGE FOR B16 OR B18C HEAD,8 INJECTORS INLET. 10 AN INLET AND OUTLET. MANIFOL IS IN PERFECT CONDITION.
$1500.00
EMAIL FOR MORE INFO rmercado414@gmail.com
Old Dec 17, 2016 | 01:59 PM
jdm inc's Avatar
Default Re: DEC FS
borg warner turbo 72mm 950 obo
round 2 motorsport wing 200 shipped
7.8l golden eagle intake manifold witih rail
700 shipped
90mm wilson tb with sf cable adaper 250 shipped
supertech valves 1mm os 150 shipped missing two exhaust
stroud harness out of date 60 shipped
gforce seoncond gear and slider 375 shipped
cams seals new 20 each
dump tube 40 shipped only have short one left
for fastest reply text me at 316 308 four three six 9
Old Dec 17, 2016 | 03:13 PM
hondatech8798's Avatar
Default Re: DEC FS
bmc racing b-series intake manifold (fits b16/gsr/ls heads)
new 76mm billet throttle body and new 3" vanjen clamp assembly
Old Dec 24, 2016 | 11:39 AM
AZ_CIVIC's Avatar
Default Re: DEC FS
Hello guys I have for sale a Garrett GTX 67mm Dual Ball Bearing T4 Open .96 AR turbo with Turbo Direct Billet Compressor Wheel. This turbo was built by the guys at Turbo Direct to test on my car, this turbo is basically brand new. The turbo made 3 dyno pulls on Locash Racing dyno and put down 870 whp in September while about 101 degrees outside.
The car made 5 passes with this turbo on October 30th IFO event, that day we were at 100 degrees and the car still put down a 9.52 pass. After the event Joe had this turbo inspected by Turbo Direct and was perfect. I just purchased the Precision 6870 to test on my car next to see what I can put down so this one is now for sale.
Looking to get 1450 OBO don't be afraid to offer.
My contact number is 480-371-8066
Pay Pal Certified
Old Dec 25, 2016 | 10:35 AM
Default Re: DEC FS
new m&w pro14 with t1 subharness with firwall cannon connector... just the pro14 and harness no gears or t1 trigger
Old Dec 26, 2016 | 06:40 PM
Blown90hatcH's Avatar
Default Re: DEC FS
S: Simpson 62" bolt-in V 5-point harness. Brand new in October 2016 from Simpson. Brand new condition. Part Number 29074BK. New was $130. Price = $100.
FS: Simpson 55" bolt-in Camlock 5-point harness. Part Number is 29108BK. July 2011 date. Good condition. New was $249 Price = $75.
FS: Simpson 55" bolt-in Camlock 5-point harness. Part Number is 29108BK. July 2011 date. Some tags removed. Will also need a couple of the clips sewn back on. New was $249 Price = $20.
FS: Helm Factory Electrical Troubleshooting Manual (ETM) for 2002-2004 Acura RSX. Good condition. Price = $SOLD
All prices are plus shipping and paypal fees.
Old Dec 27, 2016 | 08:30 AM
EF'n Sedan's Avatar
Default Re: DEC FS
AEM Series2 (6030/K-swap) Box, purchased new and in perfect working condition. Upgraded to Infinity only reason for sale.
$825 Shipped!
Old Dec 28, 2016 | 07:06 PM
11SECEG's Avatar
Default Re: DEC FS
Brand new Gato manifold for gsr 8 injector set up... if interested pls call or text 510 415-0544
asking 900 obo
Old Dec 29, 2016 | 10:39 AM
Bentley454's Avatar
Default Re: DEC FS
AEM 30-6050 Series 2 EMS
Obd2B 00-01 Integra, 99-00 Civic or universal with custom harness.
Jumpers set for T1 Cam Trigger, I can change these back if needed.
Can get pictures for interested buyers.
800.00us buyer pays shipping.
crazes
Feb 22, 2018 08:21 AM
Clayton
Oct 25, 2017 12:43 AM
crazes
Feb 1, 2017 11:37 AM
crazes
Oct 30, 2016 03:57 PM
crazes
Sep 5, 2016 02:16 PM
