need to stop spinning
Old Nov 8, 2002 | 08:17 PM
88crxsi89's Avatar
Default need to stop spinning
oh when i race at atco raceway i leave the hole at like 2,500 and it does nothing but spin then i speed shift into 2end and it spind till it hits the rev limiter then when i hit third i'm not going fast enought so it just bogges down any idead on what i can get or use to help me stop spinning?? if so it woiuld help alot thanks
Old Nov 8, 2002 | 08:24 PM
EF_LSVtec's Avatar
Default Re: need to stop spinning (88crxsi89)
Get better tires or ease up on the gas a bit...you have to go to the track more and play with it...see what really works with your set up...Sometimes you have to ease up a bit on the take off, but once you're rolling you can make up for it rather than just spinning your tires...just from experience.
Old Nov 8, 2002 | 09:25 PM
kranked91dx's Avatar
if you are running a stock internal d16a6 ----> leave the gas a bit
if you'r running a crx b18c1, boosted, full built, on nitrous, -------> Slick tire, ( Give Mr. Mickey Tompson, a call )
good luck on resolving this Tremendous problem.
Old Nov 8, 2002 | 09:29 PM
Mugen Dom's Avatar
drop the clutch at 5k no higher no lower atco isnt horrible but its not the grestest track in the world although alot of people like it....lower tire pressure to about 20 psi also
Old Nov 8, 2002 | 09:32 PM
Mugen Dom's Avatar
oh yeh ull spin alot this way but ull get a better trap speed learn to control the spin a lil with the gas not the clucth i used to practically live there and have gotten 2.1 60 ft with street tires just work on ur technique
TeamTooQuick
Jan 26, 2003 08:12 PM
95integrags-r
May 8, 2002 11:56 PM
badnan
May 5, 2002 11:45 PM
