if i change my head gasket and mark exactly the position of ea screw on my distributor will the timi
Old Nov 8, 2002 | 07:37 PM
civicracer1993's Avatar
Default if i change my head gasket and mark exactly the position of ea screw on my distributor will the timi
if i mark the alignment of my distributor screws exactly and change the head gasket and put it back how it was will the timing be the same ?
mike
Old Nov 8, 2002 | 07:41 PM
bryant's Avatar
Default Re: if i change my head gasket and mark exactly the position of ea screw on my distributor will the
should be, but i would still get it checked or check it yourself with a timming gun.
CimorelliCRX's Avatar
Just get notice where the screws have been held on the distributor for a while. You can tell like exactly how it was on. But yea if you do that, mark each spot it will be fine.
Old Nov 8, 2002 | 09:27 PM
racerxadam's Avatar
the best way that i can think to ball park the timing is to scribe a line across one of the legs of the distributor and continue scribing on to the head. when you put the dizzy back on just line up the marks.
Old Nov 8, 2002 | 09:38 PM
USDM 4G VTEC's Avatar
u dont have to take ur dizzy off in order to take the head off... but since u taking T belt off u alway s wanna make sure u still on time!
crvglenn
Honda CR-V & Element
Sep 11, 2017 03:42 PM
E-Money
Nov 4, 2010 12:19 PM
92lxinprogress
May 12, 2008 08:01 AM
macfadyen
Jan 23, 2007 03:52 PM
rollercosta123
Aug 9, 2005 07:18 PM
