AC turns on Cooling fan, Condensor fan won't turn on
Old Nov 28, 2016 | 06:46 PM
therest's Avatar
Default AC turns on Cooling fan, Condensor fan won't turn on
I have understood that the cooling fan is on the passenger side and the condenser fan is on the driver side.
If what I stated above is correct I have had the hardest time getting my condenser fan on. When I turn on my car and then turn on the AC, the compressor click on (affecting the rpms) and makes the coolant fan turn on. Never fails. What gives? What can I do? I usually hear the opposite being the issue. Thanks!
Old Nov 29, 2016 | 12:43 AM
holmesnmanny's Avatar
Default Re: AC turns on Cooling fan, Condensor fan won't turn on
100% normal
Old Nov 29, 2016 | 12:20 PM
therest's Avatar
Forgot to state that the condenser fan NEVER turns on. My car over heats a bit sometimes. If I give it direct power it turns on. Any suggestions?
Old Nov 29, 2016 | 11:22 PM
Get a set of test leads and apply battery voltage directly from the battery to the connector for the fan. If it doesn't turn on then the fan itself is bad.
Old Nov 30, 2016 | 07:41 AM
therest's Avatar
Holmesnmanny,
Thanks for the advice. I have done that and the fan works. I even stated that in my previous post. I even used a multimeter and with the ignition in the ON position and the A/C off the plug that connects to the connector of the condenser fan reads it's getting power but when I turn on the A/C it goes away. I don't know what to make of it.
E
Old Nov 30, 2016 | 08:39 AM
djkurious's Avatar
What year is the accord?
Also, have you checked the fuses in the fuse box under the hood?
There is a 15A fuse for the condenser fan.
Old Dec 1, 2016 | 01:38 PM
therest's Avatar
Yeah I've checked all the fuses. None are blown.
Old Dec 2, 2016 | 01:07 AM
When you turn on the ac and when the coolant gets to 195 degrees both fans will run. They will always run together with the exception of when the ignition is off and the weather is so hot that it will turn on the passenger side fan for up to 10 minutes to help cool the engine.
Check the ac relay. You can swap it with one of the ones for the windows. They are the same. Without knowing what kind of car you have since you refuse to provide that useful information you will need to do some searches to find where it is located for your car. If the relay is fine and the fuses are fine it's likely the fan timer is bad. You will then need to search for the location of the fan timer for your car.
Old Dec 2, 2016 | 07:32 AM
therest's Avatar
Thanks a lot holmesnmanny! 94 Accord EX. I've switched the relay with the window relay and same issue. I'll look in to the timer, coolant amount, and temperature sensor.
Old Dec 4, 2016 | 08:56 AM
poorman212's Avatar
Holmesnmanny,
E
If the above is true, something is wired backwards.
My first question after reading the above.....has the fan ever worked? If so what changed?
Old Dec 5, 2016 | 04:40 AM
therest's Avatar
I don't know if it actually ever worked tbh. I've considered just running a manual switch to get it to start.
Efbucket
Sep 3, 2007 11:55 AM
zirac50
Apr 15, 2007 06:24 PM
iLUVmyACCORD
Jul 24, 2005 08:48 PM
90Accord-R
Oct 17, 2003 07:30 AM
