first start timing
Old Nov 28, 2016 | 01:30 PM
lolv8s's Avatar
10 Year Member
Default first start timing
ok im reading about a timing gun. thought you just get everything tdc? engine has never ran. do i need the timing gun? and how do i adjust rocker arms to the right adjustment b18a1 block and head. 1996 integra coupe
Old Nov 28, 2016 | 06:33 PM
fcm's Avatar
fcm
Old Fart
Default Re: first start timing
To set electrical timing, yes you need a timing gun.
For valve adjustment Google is your friend, there are more then a few vids and DIYs on how to do that for your engine...
this is just one of them.
Valves lash out of adjustment by itself will not prevent engine start, [unless way off] you have something else wrong.
Do you have spark?
Only use an HEI spark tester to check spark, check spark on all 4 cylinders, should be bright blue.
Do you have fuel?
After start attempts remove spark plugs and inspect, are they "wet" with gas?
Have you confirmed fire order, are spark plug leads in the correct positions? 94
Old Nov 29, 2016 | 05:06 AM
lolv8s's Avatar
10 Year Member
For valve adjustment Google is your friend, there are more then a few vids and DIYs on how to do that for your engine... https://www.youtube.com/watch?v=-G_Nq2orpfo this is just one of them.
Do you have spark?
Do you have fuel?
im waiting on a break in oil. still deciding. i guess lucas? just bought some ngk spark plugs. and im picking up some cam seals this afternoon because im putting the oem cams back in. confirming the fire order? i bought some ngk spark plug wires and the length gives gives it away. although i guess they could be placed on the distributor wrong. ill check tonight
Old Nov 29, 2016 | 08:56 AM
lolv8s's Avatar
10 Year Member
Do you have spark?
Do you have fuel?
and this how to video is saying you have to let it warm up first? i havent started it yet. so i guess the electrical timing will have to be after i get it running.
Old Nov 29, 2016 | 11:02 AM
fcm's Avatar
fcm
Old Fart
that is correct, also do not forget jumper. 94
Old Nov 29, 2016 | 10:22 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Correct, so your order is, valve lash on cold engine, then start her up for the first time check for leaks. No leaks let warm up and then set ignition timing. Then hop in the car and do the break in procedure. Bring her home, drain the oil, change the oil filter and refill with your regular oil of choice.
Done.
Old Nov 30, 2016 | 06:25 AM
lolv8s's Avatar
10 Year Member
Done.
letting it idle before I run the break in on the engine shouldn't be a problem? I guess it makes since to have the right ignition timing before I run the break in...
Old Nov 30, 2016 | 09:58 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
As well, you don't seat rings on a cold engine. You have to get the engine up to operating temperature before doing a break in procedure. Setting ignition timing is a 5 minute process if that.
Old Nov 30, 2016 | 11:23 AM
lolv8s's Avatar
10 Year Member
how long should I run at idle before the warm up? And ok I guess I'll be setting the ignition timing im getting the low ball joints and front lca bushings changed and i asked if they could do it while I had it in the shop. supposed to call me back but they acted like they couldnt. should I buy the flashing light one or spend an extra 100$ and get the digital?
Old Nov 30, 2016 | 01:17 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You idle the engine to operating temperature.
You are making this WAY more difficult than it needs to be.
It's most effective to do the engine in one smooth process. Do not idle engine to operating temp, set ignition timing then shut it off only to idle the engine up to operating temperature AGAIN to do the break in process later.
Done.
Old Dec 1, 2016 | 06:58 AM
lolv8s's Avatar
10 Year Member
okay. im sorry I just wanna make sure of things.... but thanks for your help.
user1qaz2wsx
Jun 22, 2014 07:32 AM
coolswimmerjon
Sep 3, 2011 07:43 AM
civic89si666
Apr 16, 2006 09:50 AM
s2kkk
Apr 5, 2004 12:24 PM
