Need Assistance: Newly reassembled B18C1 Will Not Start
Old Nov 28, 2016 | 07:07 AM
99em1civicsi's Avatar
Default Need Assistance: Newly reassembled B18C1 Will Not Start
Had the rings replaced in my B18c1 and now that I have it back together it wont start. Ran before pulling the head fine. Timing has been checked and rechecked, valve adjustment done and rechecked. I have spark, cylinders 1-2-3 are wet when pulling the plugs and cylinder 4 is dry. Any ideas? Im using a chipped p28 with neptune. Nothing else has been changed or modified. Just pulled the head rehoned the block and reinstalled pistons with new rings. Using Injector Nation 900's.
Old Nov 28, 2016 | 07:21 AM
Default re: Need Assistance: Newly reassembled B18C1 Will Not Start
Car has been sitting since the spring. Injectors were new then.
Old Nov 28, 2016 | 08:25 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Do you have spark?
Old Nov 28, 2016 | 09:41 AM
we have spark
Old Nov 28, 2016 | 10:24 AM
fcm's Avatar
fcm
Old Fart
Default Re: Need Assistance: Newly reassembled B18C1 Will Not Start
How good is the spark and do you have spark at al 4 cylinders, only use an HEI spark tester to check spark, should be bright blue.
I would also check cylinder 4 injector or wiring to it, [because plug was dry]. 94
Old Nov 28, 2016 | 11:55 AM
Sparks nice and blue. It would still start on 3 cylinders and im getting nothing at all, not even a hiccup
Old Nov 28, 2016 | 02:10 PM
bump
Old Nov 28, 2016 | 04:15 PM
chrisc543's Avatar
Did you check compression or leak down test? Also any codes for sensors disconnected. Fuel pressure? Maybe not enough pressure?
Old Nov 28, 2016 | 05:46 PM
B and B's Avatar
Loved
Community Favorite
Grounds?
Please come back when you figure it out, nothing worse than these threads when we never hear the solution.
Old Nov 28, 2016 | 06:07 PM
fcm's Avatar
fcm
Old Fart
I you have fuel and spark then it can only be timing or compression. 94
Old Nov 29, 2016 | 12:14 PM
compression was over 150 on all 4 before i tried starting. Thats on a cold motor with fresh rings and 8.5-1 pistons. I think it has to be the timing.
Old Dec 1, 2016 | 01:44 PM
fcm's Avatar
fcm
Old Fart
You know what they say about assuming "it makes an *** out of you and me" never assume check and confirm, 94
Old Dec 1, 2016 | 06:24 PM
tony_2018's Avatar
Fish Twig
You still haven't check timing yet? wtf is 8.5-1 pistons?
Old Dec 2, 2016 | 12:09 AM
KiNGDEE206's Avatar
Check grounds aka sand off every ground
check if you install dizzy correct or if 180*'d
check for firing order
do you hear fuel pump prime
check for tdc on head and block
tchandarlis
Sep 6, 2016 09:33 PM
scotty.b16a1
Dec 31, 2012 01:54 PM
illestpnoy
Apr 23, 2011 05:38 AM
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
g2turbo
Sep 17, 2003 08:31 PM
