1992 civic sedan, jdm b20b, s4c b16 tranny CV axle help
Old Nov 24, 2016 | 02:05 PM
Purple_Hatch's Avatar
Default 1992 civic sedan, jdm b20b, s4c b16 tranny CV axle help
hello HT, i have a buddy that has a 92 civic ex sedan with a jdm b20b swap and a b16 tranny. his axles are bad and im trying to figure out what axles he will need to buy. i read that you should use the axles that are meant for the transmission that you have but theres no clarification as to whether or not that applies to the said motor.
Old Nov 24, 2016 | 04:39 PM
r_Senik's Avatar
Default Re: 1992 civic sedan, jdm b20b, s4c b16 tranny CV axle help
Any b series axles would work. Just to be safe get 94-01 integra axles or 94-97 delsol vtec axels, or 99-00 civic si axles.
Old Nov 24, 2016 | 04:58 PM
thank you sir
Old Nov 25, 2016 | 02:57 PM
94EG8's Avatar
Seagull Management
Chances are you'll want '94 - '01 Integra/'99 - '00 Civic Si or '94 - '97 Del Sol Vtec as stated. That said the real determining factor is what intermediate shaft was used. Occasionally you'll see someone using '90 - '93 Integra axles because that's what they used for an intermediate shaft (passenger's side B-series axles are all the same for those with a 32mm axle nut) Even less common would be JDM Civic B-series EF axles.
Old Dec 8, 2016 | 10:22 AM
he ended up buying 94-01 integra axles an they worked very well, thanks for the input guys
h22acd5
Mar 23, 2021 01:50 PM
longuyen88
Jun 15, 2006 07:59 AM
Turbo E
Jun 24, 2005 02:46 PM
RSciviX
Jun 13, 2005 12:37 PM
allmotoRsiR
Nov 30, 2002 10:38 PM
