what axles
Re: what axles (RSciviX)
From my looking when I had axel problems it seems that all 94+ teg or delsol dohc or 99-200si axels are same and will work, not sure about type R. You can buy the whole axle from just about any part stores. Honda only sells part axels that you would have to put together (inner outer) so dont buy them unless you have lots o money. Your old axle cannot be converted as one will be way to long. Your new tranny should have an intermediate shaft. If you dont have the intermediate shaft with your swap you will want to grab one of those as well.
Modified by wheels01 at 2:34 PM 6/13/2005
You can use either 94+ Integra LS/RS/GSR axles, 99-00 Civic Si Axles, or 94-97 Del Sol (DOHC Vtec)Axles. I'm assuming you have a manual transmission so your axles will be from a manual transmission vehicle.
Brian
Brian
Re: what axles (VtecDeMoN)
[QUOTE=VtecDeMoN]You can use either 94+ Integra LS/RS/GSR axles, 99-00 Civic Si Axles, or 94-97 Del Sol (DOHC Vtec)Axles. I'm assuming you have a manual transmission so your axles will be from a manual transmission vehicle.
HondaCRZY
02-21-2015 05:43 AM
lilpastrana
09-06-2007 07:30 AM
HamiltonRex
02-22-2006 03:58 AM
