EK Front LCA's
EK Front LCA's
Hello, H-T!
I have a stock automatic '98 Civic DX Hatchback that I attempted to do the front lower control arms on today.
Got everything apart and took off the old one but I can't seem to fit the end of the new one into the subframe.
It appears it has to be pushed in with some considerable force but I don't know how to do it.
Is there a tool? Do I bash it with a mallet/hammer until I get it aligned perfectly? It will go in to a point then stop.
It is an aftermarket control arm with poly bushings already pressed in.
Thank you!
TL;DR - can't get new front LCA to push into subframe... what do?
Thank you!
Re: EK Front LCA's
Yea man that should be cake def try a hammer. Or you can use body weight to pivot it. But I would recommend you replace the whole control arm and compliance bushing. And don't use those eBay arms, the bushings are known to be ****. If you just want some red arms powder coat the OEM ones.
Re: EK Front LCA's
So what can I do now? Should I have the bushing insert machined to fit the bolt? I really don't want to fight with the seller and wait for shipping twice to get new ones.
I guess this is what I get for cheaping out on ebay.
I like to party
Re: EK Front LCA's
It is, and you should remember this for the future. You'll be tempted again.
Safe? I guess so depending on how it's done.
But you're just going to have to pull them back off and replace the **** bushings they have in 2 or 3 months. What you SHOULD do, is return them, and buy the Ktuned or Hardrace ones. It'll sting at first, but you'll be better off in the long run.
Re: EK Front LCA's
So as it turns out, I didn't look closely enough and these aren't for my EK chassis. My noobie mistake.
Hey, everyone has to learn somewhere. It looked easy, I had the time to do it and even a second car to get around in. I learned from my mistake
bleedblue94
Suspension & Brakes
07-06-2012 01:25 PM
Ehron
10
01-17-2003 05:19 AM
