A/C, Heat not working
Old Nov 20, 2016 | 11:45 AM
Allen Harris's Avatar
Default A/C, Heat not working
I have a 97 honda civic ex when I turn the heat on it does nothing weather it's on ac or heat any suggestions would be great or simple checks before I go replace the blower motor
edit I also realized no lights come on, on the controls
Last edited by Allen Harris; Nov 20, 2016 at 11:51 AM. Reason: another noticed issue
Old Nov 20, 2016 | 11:47 AM
Former User's Avatar
Default Re: A/C, Heat not working
Are you saying the cabin blower doesn't work? If so, check the two blower fuses.
Old Nov 20, 2016 | 11:50 AM
yes doesn't matter what setting and do you know if those are located in the fuse box under the hood or under the dash?
Old Nov 20, 2016 | 11:52 AM
One fuse under hood and other fuse under dash. See FAQs sticky thread for fuse box diagrams.
Old Nov 20, 2016 | 07:00 PM
mk378's Avatar
Turn key on, set switch on high, measure voltage across the motor terminals (with the motor and everything else plugged in). If you have battery voltage going into the motor but it doesn't turn, motor needs to be replaced.
hatchy69
Oct 20, 2011 10:31 AM
ExtraBlackRex
Dec 16, 2010 03:27 PM
NOFX
Aug 22, 2009 01:29 AM
lopes316
Dec 13, 2008 02:43 PM
Arsenal
Dec 14, 2005 11:16 AM
