Blower Motor Stopped Working
So i currently have no A/C or heat in my 2003 Accord LX. I replaced the transistor but it didnt do anything. Still didnt work on any setting. Im assuming its either the blower motor itself or a fuse. Can someone tell me the fuse # i should be looking at to see if it is the fuse that needs to be replaced. Thanks in advance
Re: Blower Motor Stopped Working
The fuse is in the under hood fuse/relay box, no. 21 (40A) fuse.
If fuse is okay, disconnect the power connector on the blower motor, check to see if you are getting voltage at the connector when the ignition is on. If you get no power than it could be the blower motor relay, located in the under hood fuse/relay box.
If you do get 12 volt power at the connector, it may be the blower motor. You can also briefly connect 12 volt battery power to the blower motor to see if it runs.
