Honda CR-V & Element 2WD & 4WD Element & CR-V
03 CRV REAR 2" SPACER LIFT HELP!
Old Nov 17, 2016 | 03:40 PM
Dy2*str33t-king's Avatar
Icon4 03 CRV REAR 2" SPACER LIFT HELP!
So I bought the 2" spacer lift kit for my CRV last week and got it in yesterday. Everything looked straight forward so I tried the install. The fronts went on easily as the suspension up front had plenty of flexibility up and down. BUT when I got to the rears and tried to do the install the rear control arms and all was super stiff. I'm lost on how to install these spacers here. I can drop the strut assembly out but with the spacer on it, you cant move the control arm down far enough to reconnect it to the strut. So is there something I'm missing? been searching for an answer online the last few days and can find nothing. Any help would be appreciated thanks.
Old Nov 19, 2016 | 04:22 PM
clemsonteg's Avatar
Default Re: 03 CRV REAR 2" SPACER LIFT HELP!
Rubber bushings binding? Have you tried loosening the control srm
mounting bolts to see if that helps?
Old Dec 17, 2016 | 09:19 PM
Freefallin99's Avatar
Yep, sounds like thats the issue. I would loosen that thing or spray some penetrating fluid into the bushings, as they could be very dried out and stiff. The spray helps lubricate and increase flexibility.
Free
Old Dec 25, 2016 | 10:01 AM
ohm13's Avatar
What lift kit did you buy? Post pics please. I'm looking to do a spacer lift on my '03 and need some ideas. Thanks!
Youshady2
Suspension & Brakes
10
Oct 18, 2013 10:35 AM
raymond4486
10
Apr 18, 2009 08:58 AM
dr_latino999
12
Jul 18, 2007 10:17 AM
MiX
Oct 24, 2004 12:08 AM
