Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
06 Pilot - Factory Alarm disarm with remote starter
Old Nov 17, 2016 | 06:32 AM
btrotter's Avatar
Default 06 Pilot - Factory Alarm disarm with remote starter
I am installing a remote starter in my 2006 Honda Pilot.
Remote Starter: Avital 5305L
Bypass: iDatalink ADS-ALCA
For the factory alarm disarm, the remote starter guide say to connect:
Wire 14, green\black ----> (-) 200mA Factory alarm disarm output
In the wiring diagrams I have found online, it says:
Factory Alarm Disarm = "BLACK\RED TO BLUE (-) ON DOOR MODULE IN DRIVERS DOOR PIN #16"
My question is what exactly is it meant by "Black\Red to Blue"? Am I supposed to connect my one wire 14 to two different wires in the door module, a Black\Red wire and a Blue wire?
I don't understand how this is supposed to be connected. At the moment when I remote start the car from outside, the alarm goes off and I have to turn it off by putting the oem key in the door lock in the drivers door and turning it.
Thank you all.
Old Nov 17, 2016 | 04:19 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 06 Pilot - Factory Alarm disarm with remote starter
There is a black\red wire (from the driver's door key cylinder switch) that connects to a blue wire (that connects to the driver's door multiplex control unit. You can disregard the black/red wire and focus on the blue wire.
All you need to do is connect the aftermarket alarm/remote's "factory alarm disarm" wire to the blue wire that goes to the driver's door multiplex control unit (mcu). The blue unlock wire is at terminal no. 16 at Connector A (20-P light blue connector) at the driver's door multiplex control unit (MCU).
Old Nov 18, 2016 | 08:13 AM
btrotter's Avatar
Extremely good info!!
Thank you!!!
Old Nov 21, 2016 | 04:14 AM
btrotter's Avatar
Thank you!!!
This worked for disarming the alarm. Do you know which one of the wires would be needed to arm the factory alarm with the remote/starter key fob?
Currently I can only arm the alarm when I press lock on the oem key fob.
nrh24
Honda CR-V & Element
May 14, 2017 09:15 PM
dacohns7267
Mar 24, 2011 10:08 AM
theeogflip
May 4, 2008 05:30 PM
konidude
Audio / Security / Video
Mar 5, 2008 08:29 PM
alarmguy
Jan 7, 2006 09:08 AM
