Can't access programmation mode on a viper 790vx
Old Feb 18, 2008 | 06:50 PM
konidude's Avatar
Default Can't access programmation mode on a viper 790vx
the door is open,
ign on
i hold the valet switch and nothing happen
Old Feb 18, 2008 | 08:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: Can't access programmation mode on a viper 790vx (konidude)
Programing features or programing a remote?
Is the remote start connected? 94
Old Feb 19, 2008 | 10:29 AM
CivicPride97's Avatar
Default Re: Can't access programmation mode on a viper 790vx (fcm)
if its a remote start/alarm make sure you have the right door trigger wire (green wire from brain for negative door trigger) hooked up.....check ignition wire from remote start and make sure its tapped on right or soldered right.
Old Feb 21, 2008 | 04:25 PM
dj-t's Avatar
make sure your valet is not unplugged or cut somewhere.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicPride97 &raquo;</TD></TR><TR><TD CLASS="quote">if its a remote start/alarm make sure you have the right door trigger wire (green wire from brain for negative door trigger) hooked up.....check ignition wire from remote start and make sure its tapped on right or soldered right. </TD></TR></TABLE>
to see if one of these are the problem just arm it and open the driver door and see if it triggers and for the ignition it should lock and unlock the doors when turning key on and off or it will also trigger the alarm if turn on when armed or just remotestart it cause without the ignition it should not start.
try it if you don't want to get into the wires to test it, but if all that works my guess is that it your valet.
Old Feb 22, 2008 | 10:52 AM
8520's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">
Is the remote start connected? 94</TD></TR></TABLE>
Best question in here
I had a similar problem once, turns out my relay pack had become unplugged
Old Feb 28, 2008 | 10:49 AM
konidude's Avatar
Well, It still doesn't work, I've took the unit outside the car,
I've got the +12v, ground connected to a battery
door triger to neg
pos to relay pack pink
pos to relay pack red
still doesnt work, i press and hold the valet and noting is happening, the alarm is working fine, i see it on my 2 way remote + i got voltage on my bell
thanks
Old Feb 28, 2008 | 04:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: (konidude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by konidude &raquo;</TD></TR><TR><TD CLASS="quote">Well, It still doesn't work, I've took the unit outside the car,
door triger to neg
still doesn't work, i press and hold the valet and noting is happening, the alarm is working fine, i see it on my 2 way remote + i got voltage on my bell
thanks
</TD></TR></TABLE>Well that doesn't answer anyone's questions.
For the alarm to work, [and programing] you do not need the "Relay Satellite", [remote start] that's why I asked, and needed to know, if you had it connected.
I also asked Programing features or programing a remote? because I need to know, programing a remote is done differently then programing features.
You will need at least the Red, [12V+] black, [ground] green, [neg. door trigger] white, [light flash output] of the main harness connected, you will need the pink lead in the ribbon harness, [main brain end] connected to an ign. source, ideally a "true ign.", [hot in run and start] you also need the LED and valet/program button plugged in.
If you still can not get into programing mode, programing has been locked out with a "Bitwriter" and will need a Bitwriter to unlock it. 94
PS, getting into programing mode, either "Transmitter Learn Routine" or "System Feature Learn Routine" is a sequence of things, like open door, turn ign. on then off, press and hold valet/program button until siren chirps once, [menu 1] if you keep holding the button programing will jump to menu 2, [the siren will chirp twice] and 3 times for menu 3, once you are in the menu you want you would release the valet/program button and select the feature you want to program by pressing the valet/program button the proper number of times and so on, this all has to be done in order and within a set amount of time.
Old Mar 5, 2008 | 04:59 PM
integra1789's Avatar
im an installer and i do these every day
1. cycle the ignition
2. remove the key
3. hold button to select menu 1 or 2
4.click buttom to the selection you would like than one more click and hold.
ex- selection 4 do 4 clicks and hold on the 5th
5. wait to blink your selection
6. click unlock or lock to choose selection
7. wait for blink
8. cycle key than your done
and it dosnt matter if the door is open
if your not getting a light
check all power
check to make sure your have connections fully in
remove and reinstall all clips
check fuses car and remote start
Old Mar 5, 2008 | 06:10 PM
dc2ef9ee2's Avatar
Default Re: (integra1789)
If everything is hooked up correctly it could be locked by a Bitwriter
Old Mar 5, 2008 | 08:29 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra1789 &raquo;</TD></TR><TR><TD CLASS="quote">im an installer and i do these every day
2. remove the key
7. wait for blink
check all power
check fuses car and remote start</TD></TR></TABLE>
I hope your not talking about a dei alarm there buddy.
Because i do this everyday too and from the start I never seen a dei alarm be able to program with out the door being tag to let the alarm know its open. So I got to wave the . If so make a vid of it.
nrh24
Honda CR-V & Element
May 14, 2017 09:15 PM
btrotter
Nov 21, 2016 04:14 AM
alarmguy
Audio / Security / Video
Jan 7, 2006 09:08 AM
02Accord
Feb 21, 2003 04:46 PM
willyboyK20
Apr 18, 2002 04:51 AM
