Alarm Help please.
Alarm Help please.
I currently installed a pager alarm on my 96 civic, but I have a small problem. My alarm wont disarm when I start the car. For example.. I unlock the door (by remote), start the car, then after a minute (with the engine still on) the alarm goes back on armed mode.. what wire could be wrong? The alarm has remote start feature, but I dont need it since I live in cali and its never freezing here. I have atached my wiring
I thought it might be the door pin trigger since I got an aftermarket radio (disables domelight feature when door is open), but I jumped pin#8 (pin door) to pin#14 (domelight) from the oem green radio harness to get my domelight to turn on when the door is open.
Any advice is greatly appreciated. Thank you. I'm willing to donate $10 (via paypal) to the person who can help me get this right Thanks again.
Re: Alarm Help please. (john666)
where did you get the door trigger at? u will have to get it right at the pin for it to know the door was open and for it not to rearm.
Re: Alarm Help please. (chargedecivic)
also make sure you hooked an ignition wire up so that when the car is turned on it sends a signal to the alarm. this also resets the alarm if it has been triggered. i cant tell from your diagram which wire is for ign. but make sure that is also hooked up! try that before messing with the door pin
Re: (theeogflip)
best place to get is behind radio in the green alarm plug. it is lt. green/red or found in a light green plug above the fuse box or bottom of driver kick, harness to rear. let me know ill help all i can. ive been doing this for 15 years now so ill whatever i can for you to get you going.
glenn
glenn
