Help...Ignition switch swap...97 civic
I need to change the ignition switch of my 85 crx ... And I want to put the ignition switch of a 1997 civic in the lock cylinder housing of my 85 crx... Is it possible, will fit? Or should I change the entire lock cylinder housing
85 crx ignition switch
97 civic ignition switch
PD: Forget the different wiring between the two, I just need to know if i can put the cylinder switch
Thanks
I do not think so, I believe they went to that style in 88, and switching the whole ign. switch "system" may or may not work because of fitment and steering wheel lock. 94
But in both photos, the 85 crx and the civic 97. The white round casing is similar. It is possible to only put the cylinder of the civic 97 in the same position, maintaining the lock housing of the 85 crx .... Without changing the whole system of the key?
fazalabbas
Jan 5, 2019 10:36 PM
dr_latino999
Jan 13, 2007 07:14 AM
