Temp gauge fluctuation problem - Civic EK
Old Nov 9, 2016 | 08:29 AM
Shidou's Avatar
Default Temp gauge fluctuation problem - Civic EK
For some weird reason my temp gauge is dropping and is reacting when I put the lights on. It's pretty random to be honest.
Idle the car and let it warm up, temp goes slowly up and then is set in the middle, going for a drive, temp gauge is still spot on.
Then out of nowhere my temp gauge is dropping and it set around the middle of the temp symbol and the C symbol, sits for a bit and then goes back to normal.
On the highway everything is normal, exit the highway and temp gauge drops a bit :S
What could it be?
Fan kicks in, no overheating, both rad hoses are warm ( 1 a bit more then the other) so thermostat is working? Switched the engine coolant sending unit for a different one no luck. engine coolant temperature sensor is working because the fan kicks on. Also bleed the system so no air in the system.
Got a D15Z6 with a ESI rad in it and the rest is stock
Old Nov 9, 2016 | 08:40 AM
Former User's Avatar
Default re: Temp gauge fluctuation problem - Civic EK
Post specific car information.
Did you mean D16Z6?
Have you properly and thoroughly bled the cooling system?
https://honda-tech.com/forums/honda-.../#post38664177
Old Nov 9, 2016 | 09:50 AM
Shidou's Avatar
Default Re: Temp gauge fluctuation problem - Civic EK
Nope.. I have a D15Z6 VTEC-E.
Yes, rad cap off, heater full heat, no fan on and just let it idle until the fan came on.
Old Nov 9, 2016 | 10:02 AM
Fan must turn on twice. Does the D15Z6 have a bleeder valve?
Old Nov 9, 2016 | 10:51 AM
Shidou's Avatar
Hmm... some say need to turn on twice and the other says 1 and it's good :S
No.. doesn't have a bleeder valve... need to bleed with the rad cap off
Old Nov 9, 2016 | 11:16 AM
Rebleed using the service manual instructions I posted. If you don't have a bleeder valve, then just skip that step.
It may also help to raise the front end on jacks during the procedure.
Old Nov 9, 2016 | 04:03 PM
chrysler kid's Avatar
Check your ground cables on the thermostat and on the valve cover for any signs of contamination or corrosion and clean the contacts
Old Nov 10, 2016 | 10:48 AM
Shidou's Avatar
Did a test on the gauge and sending sensor today... couldn't do a check up on the ground points of the car because it was raining like crazy!
Gauge meter is working fine when I tested it, Sending sensor gives 240 ohm resistance with a cold engine.. Checked the service manual and it says it needs to be at 142 ohm but it's a bit vague because you can read 56 celsius but they say to check it with a cold engine :S
The ground point was de engine.. didn't got to test it when the engine is @ operating temperature
Could it be that I have a bad ground point somewhere?
Old Nov 10, 2016 | 04:11 PM
mk378's Avatar
The big wire from the battery (-) to the body and then to the engine is the most critical ground here. There is also a ground behind the instrument cluster that can make gauges go haywire. Of of course the cluster itself.
djfob
Feb 16, 2018 05:27 PM
agb22
17
Mar 7, 2017 07:11 AM
TshingY
Jan 25, 2010 12:59 PM
Da1spaz247
Oct 12, 2005 02:33 PM
