EG Civic - fuel pump won't prime (solved)
Hi guys.
I've got a b16a2 engine from an eg civic in my kit car.
I'm not getting spark or fuel pump priming. The ecu and main relay are tested and good, but I've made a mistake with the ignition wiring.
The main relay isn't getting a switched live signal when I turn the key to the 2nd position.
I'm wondering if its possible to run a feed directly from the ignition barrel to the switched live pin on the main relay?
Will this work? And will I get spark and fuel?
re: EG Civic - fuel pump won't prime (solved)
Fuses are all good. Its a problem with my wiring from the ignition barrel to the fuse box.
If I run a direct switched live to the corresponding pin on the main relay, will this work?
Old Fart
The above is a jimmy rig and would work, but I would find and fix the problem.
Keep in mind that fuse may also power other things, like the FPRS and EGR valve 94
I continuity tested everything and it all seemed fine. I was pulling my hair out trying to figure this out and just thought F*** IT! I'll just bypass the problem.
When I was removing everything I knocked the Main relay and tried it again, and it worked.
It turns out my wiring was fine, the main relay was bad after all.
I tested the thing 3 times and it was ok. Turns out that when I was bench testing it (horizontally) the dodgy solder was making contact, but as soon as i installed it back in the car (vertically) the solder lost contact and wouldn't work!
Well it's not exactly a kit car. It's more like a monstrosity of my own making.
It's a Citroen Ax. It has 2 turbo B16 engines. One in the front for the front wheels and one in the rear.
One92Eg6
11
07-03-2010 05:59 PM
Redline130
21
04-12-2006 09:00 PM
