Two question:SRS light and RPMs for 1995 accord station wagon
Old Nov 6, 2016 | 07:13 AM
wduzak's Avatar
Default Two question:SRS light and RPMs for 1995 accord station wagon
I'm a new 95 Honda Accord wagon owner. Always had Toyotas. It is automatic and I have never owned anything but manual transmissions. The car also has a tachometer which seemed unusual for auto, but what do I know.
Anyway, when I'm driving I am almost always under 2000 rpms except on the interstate when I reach 60 mph. I've always thought that anything under 2000 rpm was pretty much lugging the engine. What am I missing??
The SRS light is on and I've looked at the various solutions. Is there a problem with ignoring the light as long as i understand that the bag might not deploy in a collision?
New to the site and In all honesty I'm not sure I will ever be able to add much, but i sure could use some help on these issues.
Thanks
Warren
Nashville, Tennnessee
Old Nov 14, 2016 | 09:34 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Two question:SRS light and RPMs for 1995 accord station wagon
All Accords had Tachs, standard equipment. A known issue is a low tach reading on older Accords. Below 1500 the tach is pretty accurate, but becomes progressively delayed in higher rpms. Tach in my '95 is also faulty. Reads 2K when it is 3K and 3K when it is near 4K. There is a tach test lead underhood to hook a diagnostic tach(or any tach) up to to verify that it is the gauge that is faulty and not the igniter. Sometimes that tach issue may be from a loose connection at the top of the cluster.
I've read it can just need to be 'readjusted', never heard that on factory tachs. Or that a resistor has failed, but no one seems to know where or what to check to verify or what values to look for.
There are screws on the back of the Tach that may be the reason for the fault. But you will need ot be thorough before adjusting anything. One of the screws for the fuel gauge attachment is a lead for the fuel gauge and can be easily broken causing the gauge to read full at all times.
If the SRS lamp is on or flashing, look under/behind the glove box door. There will be two blue colored plugs, pull down the two wire blue plug. Jumper it with a wire. Turn the ignition switch to II(ON) and count the blinks from the SRS lamp.
Originally Posted by Speedy5966
HONDA Motor Company 1988-2002
DIAGNOSTIC TROUBLE CODE Definitions
Specific Fault
1-1 & 1-2 open circuited Or high Resistance In Drivers Air Bag Inflator
1-3 short circuited To Another Wire In Driver's Air Bag Inflator Or low Resistance
1-4 short circuited To Power Driver's Air Bag Inflator
1-5 short circuited To Ground Driver's Air Bag Inflator
2-1 & 2-2 open circuited In Passenger's Air Bag Inflator
2-3 short circuited To Another Wire In Passenger's Air Bag Inflator Or low Resistance
2-4 short circuited To Power Passenger's Air Bag Inflator
2-5 short circuited To Ground Passengers Air Bag Inflator
3-1 & 3-2 open circuited Or high Resistance In Driver's Seat Belt Tensioner
3-3 short circuited To Another Wire Or low Resistance In Driver's Seat Belt Tensioner
3-4 short circuited To Power In Driver's Seat Belt Tensioner
3-5 short circuited To Ground In Driver's Seat Belt Tensioner
4-1 & 4-2 open circuited Or high Resistance In Front Passenger's Seat Belt Tensioner
4-3 short circuited To Another Wire Or low Resistance In Front Passenger's Seat Belt Tensioner
4-4 short circuited To Power In Passenger's Seat Belt Tensioner
4-5 short circuited To Ground In Passenger's Seat Belt Tensioner
5-1, 5-2, 5-4, 5-5, 5-8, 6-1,6-2, 6-3,6-4,6-5,6-6, 6-7,6-8, 7-,1 7-2, 7-3,8-1, 8-2,8-5 & 8-6
Internal Failure Of SRS Unit. Check Battery System Voltage, If Voltage Is Low , Repair Charging System Prior
To Troubleshooting SRS System
9-1 SRS Failure Or Indicator Light
9-2 SRS Unit Internal Failure Of Power Supply
10-1 SRS Air Bag Deployed
Old Nov 15, 2016 | 04:22 AM
wduzak's Avatar
Thank you for taking the time to reply. I appreciate it very much
eddi1984
Jun 17, 2015 02:20 PM
- 8 -
Jan 5, 2012 12:07 PM
journeyforce
Mar 22, 2009 04:25 PM
jmunderfire
Nov 27, 2007 03:42 AM
mikeb33
Jun 13, 2005 05:35 PM
